Go Back   R/C Tech Forums > General Forums > RC Flight
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-05-2009, 04:10 PM   #1
Default inverted flight
how do you fly upside down with a blade cp+
rc kid7 is offline   Reply With Quote
Old 08-07-2009, 10:13 AM   #2
Joel J's Avatar
Trader Rating: 20 (100%+)
If your not sure how to do it then i suggest to practice on simulator or you will crash..
Shepherd V8 / M11X
Joel J is offline   Reply With Quote
Old 08-07-2009, 01:49 PM   #3
grouch's Avatar
Quick pump a touch of collective, hold the cyclic to one side and wait until it goes over. Pull negative collective and count the seconds until you get disoriented and put it in. Rebuild and repeat.
-Jarrett
grouch is offline   Reply With Quote
Old 08-07-2009, 03:58 PM   #4
monster271's Avatar
LOL!!!!!!!!!!!!!1
monster271 is offline   Reply With Quote
Old 08-28-2009, 11:01 PM   #5
Inverted + Rc heli= floating lawnmower!
rgsuperstart is offline   Reply With Quote
Old 09-01-2009, 04:39 AM   #6
tadelk's Avatar
Send a message via AIM to tadelk Send a message via MSN to tadelk Send a message via Yahoo to tadelk
On the right side of your remote you have a switch called "idel up" This switch is used for acrobatic and inverted flying. Idel up switch will cause the heli to stay in idel up mode and when you pull the throttle down wards you are really changing the pitch of the rotor blade to force the heli down wards fast at high idel. That is use full for inverted flying. When your upside down and your in high idle mode and you pull down on the throttle you will make the heli climb. Push the throttle up and you will make the heli decend. This only works when your upside down. Always remember to flip the switch back to normal mode before you land or you will be spending alot of money in parts like me.
Thanks,
Todd
tadelk is offline   Reply With Quote
Old 09-21-2009, 04:36 PM   #7
helibrian's Avatar
OOOOOh!! you forgot to hit idle up! Good explanation though, that's exactly how I do it.....1 mississippi...2 mississippi......
helibrian is offline   Reply With Quote
Old 09-22-2009, 07:31 PM   #8
You need to make sure that the heli is set up correctly in idle up. It should be set with 0 pitch at center stick and an equal amoutn of positive and negative at high and low stick, and it should stay at full throttle thru the entire range of the stick! If your not sure, get someone that knows to look at it! it will save you alot of heart ache!
rc.chris is offline   Reply With Quote
Old 10-15-2009, 05:52 AM   #9
I'd have to say +1 to this one. But if you think you are up for it, make sure someone has a video camera I always love watching videos of people wadding up their CP machines lol
Great Lakes RC Online
The definitive Great Lakers meeting place...
www.greatlakesrconline.com
mschaffer66 is offline   Reply With Quote
Forum Jump
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 44296 Yesterday 09:01 AM
RC FLIGHT brading Manila Racers 21753 11-19-2009 09:54 PM
HAWAII Pavement Pounders KPRacer Racing Forum 4193 11-19-2009 06:02 PM
Cebu RC Fly Boyz jpn Manila Racers 3459 11-12-2009 08:29 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
Any beginner recommendatios? amp3d RC Flight 20 07-31-2009 05:32 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
