Traxxas DCB M41 Widebody...
I'm surprised this hasn't been posted up in here yet. I'm holding on to hope that they offer some less intense hull color options, but the boat looks like it'll be a blast. Great bang for the buck.
https://traxxas.com/products/models/marine/DCBM41
I like the idea, but its all plastic. I had one of their vee hulls and got rid of it for that very reason. And trim tabs on a cat?? They are not needed.
I've owned some MHZ cat hulls that would run circles around the DCB, but each cost (conservatively) 3 or 4 times as much once they hit the water. Factor in Traxxas' customer support and parts support, and it's an appealing package for those that just want something that's 100% ready to hit the water.
Even as a long time racer/hobbyist, this boat appeals to me. I'll admit that I'm swaying more towards form than function in this case, but it's obviously not a slouch in performance, either. I'd likely remove the trim tabs and work on adjusting the boat's attitude with the drive and battery location. I assume Traxxas added them to prevent newer drivers from constant blow-overs.
For $450.00 I'd expect more than a plastic hull. The trim tabs must be a Band-Aid fix for a poor-handling hull.
With the Courtney Force inspired paint scheme it still looks like the painter dropped acid.
After the $450.00 you'd still have to buy battery packs and a charger if you don't already have them. It won't be fast enough then out comes mo' money for upgrades.
Have you been reading my postings on Facebook again?
I bought this boat. I have had some fun with it. Running on 6S. Couple of things to note:
- The water cooling is USELESS out of the box. The single rudder pickup is a joke, and the electronics get very hot, very fast. It is almost criminal that Traxxas would sell this boat as it is currently setup.
- The vercro strap system for the batteries is poor. I needed to add lots of stick on velcro to get the batteries to hold.
- I love the color theme. The boat is great looking, and looks great on the water. It is a nice size, and the cockpit detailing is great.
- Very easy to work on, with the exception of getting the batteries to hold in place with the straps.
- Did I mention the cooling is USELESS. I do not know how a company the size of Traxxas can mess that up so bad. You only have the drive the boat for a few minutes to realize the electronics are not being sufficiently cooled. Also, throw away the included motor jacket. It leaks like crazy.
I have plans to add a new rudder with dual (actually functioning) pickups. I have added RC Boat Bitz trim tabs and a motor jacket. I also added a CNC prop, however the electronics overheated almost immediately, because there is very little water cooling them.
Great boat for a toy. All you need to get it setup correctly is about $300-$500 in aftermarket parts, lol.
I've seen barely used ones going up for sale on some Facebook RC boat groups already.
Sounds like the exact same issues the spartan had when it first came out.
Good to know... Few guys i know run the Aquacraft Motley crew and love it. Fiberglass and RTR for $350.
great to know for Traxxas lover
Water cooling not worth a S..t.
Wow boat worked great the first time. After that its been a disaster. Motor not getting enough cooling, Prop - cable drive wont stay locked in. Rudder intake is not clogged but insufficient to keep motor cool. What parts do you recommend for the dual intake and water jacker.
This conversion kit is kinda pricey, but it sounds like it'll solve all the problems inherent with a stock Traxxas boat.
http://www.proboatmodels.com/Product...rodID=PRB08021
