Traxxas Spartan cooling mods
My Traxxxas spartan over heats bad and causes a shorter life to my batteries.
I have tried 1 mod with the water splitter it works but worse that stock set up. So i'm now ordering a double pick up rudder and a new prop/prop nut. question is, the double pick up rudder is it enough? or do I need a new Cooling jacket for my stock motor?
Other Question will lower motor temps increase runtime and battery life?
I new cooling jacket would help, they are not much money. How long are you running the boat? It should be ran 5 mins top per run. Boats suck a lot of amps from batteries and they discharge and heat up fast.
does that have to do with the battery temps?
Another good Mod it to get a new rudder that has Dual Pickups. that way your motor and esc get fresh water
