brushless Reef Racer2
well i finished my RR2 conversion. I'm loving it, its fast and the darn thing turns on a dime! i got a 2200kv motor and paired it with a 60A water cooled esc. i also bought a new motor coupler from an aqua craft tugboat and no drilling was necessary it slipped right on the motor and prop shaft. im running it on 2s 1200mah and 3s 1500mah. i will be posting up pictures and video soon.
motor specs:
http://www.hobbycity.com/hobbycity/s...idProduct=4201
Motor Size: 2835 (380S)
Speed: 2700kv
ESC Required: 25A
Voltage Range: 6~12v
No Load Curr: 1.2A
Max Load: 35A
Diameter: 28.2mm
Length: 37mm
Front Mounting Hole Distance: 19mm
Front Mount Thread Size: M3
Shaft Diameter: 3.2mm
Shaft Length: 12mm
Weight: 102grams
Boat ESC:
http://cgi.ebay.com/ws/eBayISAPI.dll...t_3724wt_11377
Output: Continuous 60A, Burst 80A up to 12 Secs. (no backward)
Input Voltage: 60A: 2-6 cells lithium battery or 6-20 cells NiCd/NIMh battery.
Weight: 60g.
3A BEC
motor specs:
Speed: 2700kv
ESC Required: 25A
No Load Curr: 1.2A
Max Load: 35A
Diameter: 28.2mm
Length: 37mm
Shaft Length: 12mm
Weight: 102grams
Boat ESC:
Weight: 60g.
3A BEC
Your link for the motor is broken. Have any pics of it all setup?
