prop
prop
Hi guy i need helps for find a good prop for my rigged insanity i have a feigao 540 8XL and a ETTI 150 amp i need a couple suggestion for a good prop
THX PIERRE
THX PIERRE
How much cells, nimh or lipo or life batts, what is the length or the rigger?
I drive with 4s lipo and my boat is 29 inch long i have a feigao 540 8XL and a ETTI 150amp for my speed control and do you now what is suppose to be my running time with that i run the last time and my running time was juste 3-5 minute
Start with a 32mm prop with a max size of 40mm. My cat is 32inch, has a 6XL motor (2370KV), 125A Etti, 4s lipo and I run a Octure X437 3blade prop. My runtimes are about 7-8 minutes with a max speed 66km/u
Guest
prop
1.4-34.5, carbon fiber or a cf 36mm or a 37.5cf but with a Feigeo, watch the heat, tendency to get warm.
