turnfins/trim tabs ?'s
On my grey thunder it doesn't have trim or turn fins.How do i figure out what size of these i would need?Its about 24" and is a vee fin type boat.Right now in the stock form it is now when i turn it spins out.Will these help?Also i need to get a sealed radio box does any one make them?Where can i find them if they do.Thanks
radio chambers: http://toys.shop.ebay.com/items/?_nk...ox&_osacat=220
Guest
turnfins/trim tabs
Age old question.
Age old question. I'd make my own turn fins and put one on each side of grey and have the height just above the keel in a tear drop shape and slanted back alittle. Now trim tabs is a poor bandage for a poor setup. Now if you want them, fine, just make your own out of .064 aluminuum sheet size 10" x 4" from LHS. Make the 1 1/4" wide and 1 1/4" long and the add 1/2" for the bend. Make the turn fins 90 degrees to the bottom of hull. Make tabs flush with bottom and neutral. They do add drag tho. I have 22" monos with no trim tabs and run with twin turn fins and work great. Trim tabs are for loos. Really long turn fins add drag. I have a No Step 1 with no t/tabs and small turn fins and turns on a dime, not for sale.
Guest
turnfins/tabs
Check back later.
The fish tailing is because of the steering out drive.Yes set-up does have some to do with it but turn fins will help keep the rear from sliding out in a turn.I know i could get a stinger and new steering fin set-up but i can't afford it right now so i'm just trying to get this thing drivable till i can upgrade to those.
