Here's the formula:
X440 is 1.4 x 40. You multiply 40mm x 1.4 to get the pitch, 56mm. So you can see that if you go to a X640 prop, it will be the same diameter, 40mm but will have more pitch...1.6 x 40 = 64mm. Now don't go asking me how to figure out Prather and ABC props. Haha! At least the Octura's are easy. The same goes for the 4 digit numbered props like 1640. It is 1.6 x 40 also but has a different blade design. For example, the M series props are the same as the X series prop except they do not have the tongue on them. Some props are lifting props, etc.
[quote=chunk t;6040504]It's there, you just don't realize you're looking at the pitch number.
diameter: 1.6" = 40mm
pitch: 2.5" = 63.5mm
The closest matches by Octura will be either a #1640 (straight pitch) or X640 (progressive pitch) these are both beryllium/copper alloy and fit a 3/16" hub shaft. I'm going to guess that you are runing an electric motor vs a nitro engine, 'cause a 1640 doesn't find it's way on to many nitro hulls in stock form.
