Go Back   R/C Tech Forums > General Forums > RC Boating
Thread Tools Search this Thread Rate Thread
Old 02-26-2009, 01:24 PM   #1
racingnazy's Avatar
Send a message via MSN to racingnazy
Default S.O.S. Traxxas Nitro Vee
Looking for someone who has or knows alot to do with the Nitro Vee. I start mine and it takes off and stalls. It is bran new but I have played with all the setting, I know i shouldnt have but I want it back to start. It doesnt even have a tank through it yet
PM's Please your pal Curtis
Team Desert
racingnazy is offline   Reply With Quote
Old 02-27-2009, 09:31 AM   #2
chunk t's Avatar
Curtis, when does it stall? When you get on the throttle? Imediatly after hitting the water? after 2 min of running?
The engine should run with a "burbbling" sound out of the water. Should sound like it's choaking on the fuel. If it continually dies when it is pitched into the water than you are too rich. Other wise it's running lean and need to be richend up.
BTW to launch a nitro boat you don't set it in the water, you give it a toss so it has some good forward momentum when it hits the water.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 03-03-2009, 04:37 PM   #3
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Send a message via AIM to chewiefttc4 Send a message via Yahoo to chewiefttc4
uncouple the motor/clutch from the driveline. and make sure the driveline turns freely even with full left and right steering... then if your good there. then check the clutch springs.. to make sure they arent engaging early.. if they feel weak then replace the clutch shoes/springs then check the clutch bearings to make sure they spin freely.. replace if needed..
if thats all good then look into tuning. once you get tuning down then restrict the outgoing water cooling hose.. at the head with a zip tie... stick the tube out the side of the boat. to check the stream..(i say this cause the water cooling is dumped into the exhaust.)
at full throttle/full speed it should barely stream out the tube.. 1 to 2 inches maximum
if water moves too fast through the cooling head it doesnt give the motor enought time to exhchange heat to the water. so you get overheating.
also check to make sure you have a good seal on the fuel tank and no holes in the fuel line.. retune slightly leaner than startup/breakin procedure and start from there. also make sure you have a fresh glow plug...
sorry to ramble on
High Velocity Racing,renos ragu,castle creations,
rc8 awaiting new life as electric 1/8
whoever said power isnt everything obviously doesnt own brushless/lipo power
dirty glove racing
rdub202s pit/mechanic rofl. (come back mang!!!)
chewiefttc4 is offline   Reply With Quote
Old 05-12-2009, 03:10 AM   #4
MrUnlimited's Avatar
Are you using the stock prop or did you change the prop?
http://www.v10power.ws
MrUnlimited is offline   Reply With Quote
Old 05-12-2009, 09:33 AM   #5
I had a similar problem when I first started and of course I had to mess with everything before troubleshooting the initial problem. To make a long story short the problem was that the fuel mixture was too rich. After I had a local dealer fix the problems I created, we made a leaner mixture and the boat ran great.
scootrmcgavn is offline   Reply With Quote
Old 08-10-2010, 06:08 PM   #6
racingnazy's Avatar
Default thanks guys
its time for a total rebuild I think. The motor runs fine sitting there. But once its in the water it goes about 2-3 feet then stalls. Ive got it tuned good I THINK.. im going to try all the lines, and then the clutch springs. seems to be a hard part to get to.
ill keep my progress posted.
Team Desert
Old 08-13-2010, 12:41 PM   #7
dont forget that putting it in the water adds lots of stress to the engine and drive line which means you may want to mess with the mixture screws a bit more. I had this problem with my 30cc boat. As soon as I put it in the water it would cut off. Keep trying and good luck!
My 58'' boat build! -- http://www.rctech.net/forum/rc-boating/387166-58-boat-build-please-comment.html
USAF Weather
F15pilot is offline   Reply With Quote
SEO by vBSEO 3.5.0
