Seems your engine running too rich. Is your glowplug shiny when you take it out? Close the needle with 1/8 turn in and try again. Before you run the boat again, clean the engine and pipe with wd-40 and after running use only 2 drops of afterrun oil adn a small amount of wd-40. Next time you start the engine both the afterrun and wd-40 will be burned.
4s LIPO fast electric brushless catamaran 32inch
1/8 scale .67 Picco powered Formulaboats.com hydroplane
Team Magic M8 K-Factory version with 7P Go Engine
SANWA M11 2.4GHZ radio
