Go Back   R/C Tech Forums > General Forums > RC Boating
Thread Tools Search this Thread Rate Thread
Old 11-07-2017, 09:31 PM   #1
KristofferR's Avatar
Default TechToys V24 ”rebuild thread”
This is my first new thread at rctech. I used to hang out at URC. Hope you like it!
RC power boats are something I know very little about. I built one back in the 80’s and powered it using an old slotcar motor. I drove it once and put it on the shelf.
Recently a friend who is into rc boats gave me a couple of leftover hulls. He is not knee-deep in RC like I am, between building a house, work and family he sometimes run RC boats in the evening to relax. He gave me a used Tech Toys V24 and one a NIB Graupner Speedy.
I decided to start with the V24. The Speedy deserves more knowledge than I currently possess, I reckon.
The V24 is a toy-grade boat - Mhz radio, fully integrated electronics, steering using dual 380 brushed motors and cutting power to one side to turn.
The motors were rusty and seized. Props broken. Transmitter non-existent. Lots of sand inside - from running in sea water.
After looking at the boat a few weeks and googling a lot I realized shafts and props were toy grade too and not easily available as spares. Two new 380:s and dual brushed controllers and using a delta mixer would have been neat but buying all that meant a) minor performance improvement and b) cash out.
I just pulled everything out and scrapped it. In my box of leftovers I found a Racerstar 540 brushless motor used in my MERV. Then I ordered some random axles, props, rudder etc from Bangood.
KristofferR is offline   Reply With Quote
Old 11-08-2017, 12:39 PM   #2
I used hotglue and some scrap pieces of wood making a motor mount
Motor in position with a shaft from Banggood and a makeshift guide.
Just before testing the system. It sounds pretty cool.
Weight check; dont remember the numbers!
Orange is the new black. Or the opposite. I painted the windows black and put a stripe up front. It still looks meh but before it was worse.
Banggood rudder and snakes from my collection of RC airplane stuff. No cooling yet, TBD after first run.
Old 11-13-2017, 03:32 PM   #3
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
I would use epoxy vs hot glue from past experence.
roadrashracing is offline   Reply With Quote
Old 11-14-2017, 12:35 PM   #4
I’m normally not a hot glue person, do you think it will melt, get brittle - what happened to you?
Old 11-14-2017, 02:14 PM   #5
Moderator
I had problems with the glue holding to the plastic hull and it just pulled away. I would get a mount like this and two part epoxy, scuff hull. https://www.offshoreelectrics.com You will probably also want to go with water cooled electronics, boats draw lots of current and stuff gets warm quick.
