Futaba r203gf vs r304sb
Hi to everyone.which of this receiver is faster?or is the same in terms of speed except telemetry option in r304sb?
R/C Tech Elite Member
I'm no expert and futaba doesn't do a good job of advertising, but I can't feel a bit of difference in them. I've got several of both.
For comparison, when I use my daughters setup some of her cars have an axion 2 and some have an axion 4 and I notice a difference when I'm driving on a high traction track as I will turn into the pipe on 180's if I go from the 4 to the 2 back to back. I believe the telemetry is the only difference in the Futaba RX's so I've just started using the cheaper version as I don't use the telemetry anyway.
Look at the Benchmark thread http://www.rctech.net/forum/radio-el...m-results.html to see raw data about both receivers. I have used both and for me there is a noticeable difference. Tested on 4pls and 4PX - on the last one more obvious.
What servo do you use? Maybe servo is slow and that's why. Check servo saver if you use it. When sloppy all gains are lost.
You have to ensure that telemetry is turned off and that you are on 'Racing Mode' in order to get the really high speed feel. If you're not sure how to do those two things, just google it and you'll find the steps. It's rather easy to do, I just don't have them in front of me at the moment.
