Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-20-2017, 01:40 PM   #1
Default Control options
Hi All,
I've finally took the plunge and bought myself a second hand tx/rx as an intro into RC. I have a project in mind - a simple car build.
I am looking at building my own car/bot as a fun project. Anyway, as I see it I have 2 options for steering;
OPTION 1 (preferred) - Drive 2 wheels separately with 2 ESC's and "mix" the channels to provide steering (I'm assuming "mixing" will decelerate either left or right depending on direction?). This will leave a channel free to run a servo for some kind of feature.
OPTION 2 - Drive 1 drive motor with the throttle stick and a servo with the other to provide steering the front wheels.
Firstly, is option 1 possible with the transmitter I have? If so, which channels and switch configuration should I use.
Thanks in advance. I am new to this but keen to learn through research and giving things a try!
Regards
Paul
Pjl83 is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45697 07-20-2017 08:46 PM
Traction Control - How do you do it? CloseYetFar Electric Off-Road 19 02-26-2013 09:26 AM
buying a Radio/Transmitter/Controller...Whatever it's called. Roodki Rookie Zone 7 03-10-2006 01:14 AM
