Recommend a charger for me >
Like Tree1Likes
Old 02-15-2017, 05:29 AM
  #16
I went with Polaron.....works great with lots of Extras
Jo2fst4u is offline
Old 02-17-2017, 09:19 AM
  #17
nodrog's Avatar
so the hitec x2 will charge at 7.5 amps not 10 amps per channel?
Originally Posted by Eddie_E
I hope you realize that you can only charge at 15A total with the Hitec even though the box says 10A on each channel. The power supply is under-sized. You also can only do 1S lipo on the first channel. If you race 1/12 this is a big problem.
The Reedy 1216 C2 /Ultrapower does a real 12A on each channel (24A total)and it does 1S~6S on both channels. The fan is also temperature controlled, so you don't have it screaming full blast all day.
nodrog is offline
Old 02-17-2017, 11:20 AM
  #18
You can charge at 10A ONE channel, the other gets what's left so 5A. there is an adjustment in the setup to set the bias between the 2 channels, so you can make it 7.5 and 7.5 if you change it in the setup menu.
Eddie_E is offline
Old 02-17-2017, 11:29 AM
  #19
A curious statement as the Hitec X2 AC Plus can do max 10 amps and 1-6S on both channels. On AC power it's 100w total power, split between the two channels how you want. On DC power it's 100w power to each port. This is due to size constraints, a 200w AC power supply is significantly larger than the charger case allows.
If you run DC power you can charge 2, 1-2S packs at 10 amps each, 6 amps on 2S and 10 amps on 1S if you use AC power with 50/50 power distribution.
Xpress.. is offline
Old 02-17-2017, 12:29 PM
  #20
nodrog's Avatar
so 6 amps max on each channel using AC power?
I'm trying to help a person new to lipos find a decent little charger, he has 8200 mah batteries for his summit but it appears he won't be able to charge at 1c with this charger
so at that, would there be any concern running the charger at max?, even if it is 6amps
nodrog is offline
Old 02-17-2017, 12:34 PM
  #21
My Hitec X2 AC plus will not allow me to set my bottom channel to 1S 3.7V. Did you guys have an update recently? I see the picture above has that.
Eddie_E is offline
  #22
Depends on the cell count. Charger watts / pack voltage = max amps.
You can also put the full 100w AC power to either one of the ports if you need the extra juice.
Xpress.. is offline
Old 02-17-2017, 12:52 PM
  #23
nodrog's Avatar
2s 8200mah both batteries charging at the same time
max amps on ac power?
nodrog is offline
Old 02-17-2017, 01:01 PM
  #24
dtr
dtr's Avatar
About 6A each.
dtr is offline
Old 02-17-2017, 01:06 PM
  #25
nodrog's Avatar
ok thanks, i'm trying to help this guy out and when i explain all this to him I want to pass on the best information possible. He's hoping for the best turn around time on his batteries.
6 amps isn't bad and I can leave the choice up to him, in the product description it says 10 amps......on a dual channel unit i was thinking that's each channel
thank you for the help
nodrog is offline
Old 02-17-2017, 02:43 PM
  #26
It is capable of 10 amps maximum per port. That does not mean it will charge at 10 amps on every battery you plug into it, it just means that it can do up to 10 amps as a maximum.
Xpress.. is offline
Old 02-17-2017, 02:56 PM
  #27
nodrog's Avatar
thanks for your help, it looks like a great little charger with some cool features
nodrog is offline
Old 03-13-2019, 07:20 PM
  #28
Originally Posted by Davidka
I'm enjoying my new Ultra Power 100AC Duo. It was $70, charges 2 batteries at a time of any chemistry and is nice and small. There are several brands that re-label UP stuff.
Digging up an old post, but have you tried charging LiHV batteries with this charger? I have this charger as well and am looking to switch to HV batteries. I wasn't sure if I can just use the LiPo setting to charge LiHV, or if I need to get a new charger as well.
Cheers.
Jumbo_Jaque is offline
Old 03-13-2019, 11:58 PM
  #29
Roelof's Avatar
LiHV are just LiPo's so yes, you can charge them on a LiPo program. You can not charge them on a higher voltage but with most racing that is not alowed and if is is alowed you can look if you can set the end voltage in the LiPo program (some advanced chargers have options to finetune the voltage.)
Jumbo_Jaque likes this.
Roelof is offline
