Need a new charger, what's good?
I need to get a new charger, want a good one, what should I get? Thanks for your help, Dave.
The I charger 406duo is a great unit, ive been using one for a couple of months now and it balances within .001 a cell or most times the cells are even. Awesome discharging aswell when combined with the external discharge unit.
I'm racing 2wd buggy, stock 17.5.
Thanks for all the help, I think I'll be going with the icharger.
I have been using an i106 for smaller batteries and an i306 1000W for like four years now. If I was buying a new I'd be getting the i406 Duo like other have suggested. A few years back I carefully compared icharger to similar model from FMA Powerlab. The icharger had way more balancing current. Balancing current is always much less that charging current. So you might charge u fast at 3C but then balancing can take a long time if one cell is off.
The i106 only balance at 100mA. The i306 is a bit better at 300mA. The Duo models balance at a whopping 2.4 amps or 1.2 amps per channel.
The Graupner Polaron EX Chargers are very good. It can do alot. You can get one from Tower Hobbies.
can someone explain the advantage of chargers that need a power supply over the chargers that plug into a regular power socket?
Also make sure you match the power supply to the charger. ichargers will run pm 12V but the higher power ones need 24Volts to works at full power.
