No Antenna Tube Look
http://www3.towerhobbies.com/cgi-bin...P?I=LXBPKM&P=8
I use receivers with no antennas.I'm not sure if that's an option for you depends on what radio you use..besides that I use antenna tubes.
You can get away with leaving the antenna coiled up inside the reciever box although I'll use an antenna tube and just have the white (the actual antenna) not all the black antenna wire just poking out of the reciever box and into a short piece of tube that I bend and form so it stays under the body.
I arch the antenna tube between the antenna tube mounts on both sides of my B6d. Fits under the body and keeps in out of the way.
No drawbacks just + there small and fit just about anywhere and make for a nice clean install.Also very affordable if you order 2 from tower hobbies and use a coupon code.they come out to about $34.50 a piece
I use the same futaba receivers, don't forget the quantity discount below the picture on towers website. Then stack a coupon onto the order and its crazy cheap.
