5 amps on 17.5 & no real difference
I raised my timing on my 17.5 motor and got 5 amps out of it. Didn't see much of a difference except for lots of extra heat. I tried different gearing starting at 30/69 and up to 32/69 and it ran way hot with not much improvement in performance. The buggy was actually faster around 2 amps. What gives?
Did you try going both ways with the gearing? What's way too hot? A number or going by feel only? How long did you run? And double check your out drive bearings, etc to make sure they aren't bad.
What do you mean both ways with the gearing?
Motor analyzers don't replace the feel.
Also, is there a fan on the motor? Unless it's a tekin gen 3, a fan is required.
Motor, weight, gearing, timing? What car?
I don't run stock/spec classes much because I like to run cheaper equipment and just motor up. The little bit of 1/12 scale racing I did last winter was 17.5 blinky though, and like you, I didn't notice a ton of difference between a motor pulling 2 amps and the same motor pulling 5 amps. I would suggest just playing with your gearing more, and stop using the temp gun. If it literally burns your finger, it's too hot. If not, then you're good. I don't know what recommended temps are b/c I'm too lazy to google it, but 160 sounds pretty conservative. Abusing equipment is the byproduct of running a class that isn't open (mod). Take your pick if you want to abuse your motor or your batteries, or both My advice is if you liked it at 2 amps, run it there. If you're having fun you're doing it right.
I have ran a few variations of the base motor on a 6500 sq ft track,
I do use a fan just in case it gets a little on the hotter side than I'd like.
I found that 50-55 degrees of motor timing and a gearing at 30-31/69 had the best feel. I usually will normally run a 10min +4-5 laps in a practice session and if it doesn't feel like it's hot or fading, I know it'll be solid for the 8 minute mains we run locally.
What size track?
Did you check your amps on a multimeter? Best way to find out what your pulling. The numbers on the can aren't always accurate.
It's a medium/large track. Not too technical, it's more for speed with one big jump basically. Hard packed clay. My motor felt best at around 30-40° but the Amp were way low compared to the other guys with the same motor.
If the 4 I've ran they all seemed to be happiest at those settings, no matter the layout we've had locally, currently a 18-19second lap time for most of the stock guys. I am swear that the timing numbers on the can can be off, which would probably explain why all my motors I've ran fall in that 50-55 area to have the feel I like out of them.
I'd try that gearing with that timing and see what the lap times say.
General rule of thumb
More motor timing=less (smaller pinion) gearing
Less motor timing=more (larger pinion) gearing
Both are for the same spur used
I do know a few guys that run the AE cars and seem to like the 72 spur from avid or scheele more than a 69. I didn't like it as much and stayed with the 69
I have a motor analyzer and the Trinity motors seem to have a fine line between power and heat. Most I have tuned loved 48-52 degrees timing with heat climbing very fast if you go above that. 32/69 is the most popular choice for gearing for most B5M cars I help with. A fan is a must when bumping up your timing.
