Options for Stock Tekin Caps
So, I'm pretty much fed up with the capacitor on my Tekin RSX. No matter how I mount it the legs eventually bend & break. I used servo tape to stick it to the case but it was the same issue.
Could I use a capacitor from another ESC that has the same specifications as the Tekin cap? Capacity: 330uF*2.
Voltage: 16V
This cap comes with long, flexible wires, gonna mount the actual cap to the RX.
Thanks in advance
Voltage: 16V
Thanks in advance
You certainly can. However, you need to make sure you choose an equivalent or better capacitor than the one Tekin provided.
Your capacitor needs to be rated for 16v or higher, be 330uF, and have as low an ESR as possible. This third detail might not have been very apparent. It explains why manufacturers use a particular capacitor, and why they mount it as close to the ESC as possible. Basically, the lower the resistance (and ESR), the better.
Digikey.com has thousands of capacitors. What you are looking for is an aluminum polymer capacitor, with the above properties. Search for that kind of capacitor, with 16v rating, 330uf capacity, Through hole mounting. Then, look at your options, and choose the one with a low ESR. Be sure to look at the physical dimensions, to make sure it will fit in your vehicle. Cost goes down as you buy more, say 5, 10, 25, etc. Shipping will be around $8 or so.
Or, you can try a cap from another ESC, but with this there is uncertainty it will be better than the Tekin.
To prevent the leads from breaking in the future, apply plenty of rubbery glue to keep the cap from shaking. E6000 is a great glue that I have used.
Thanks again.
Did you mean ESR?
ESR stands for Equivalent Series Resistance. The smaller this resistance, the more current the capacitor can provide at any time.
Its like a straw for a soda. If you want to drink really fast, you want a big straw (low resistance). You could also use two straws to do this, and get double the drink (half the resistance).
In practicality, most capacitors would probably work fine.
Did you mean ESR?
Some people might be tempted to use the Super Capacitors because they see very large capacitance numbers, but super capacitors have a very high ESR and are not suitable for use on an RC speed control.
Xerun Super Capacitor Module. Same specs as the stock cap. The 2 caps don't look that big. But, I'd like to be sure. I tried to include a link to the amain.come page but couldn't do it.
Its called a "super capacitor module", but it does not use actual super capacitors; it consists of regular polymer caps. Hence, their ESR should be low enough.
R/C Tech Elite Member
When I queried this with Tekin when I ran their esc's I was told to only use the stock caps, and that any other caps could cause issues, void warranties etc
Given the price of their gear I'd just use what they say.
Personally I've gone to another brand now which I have had a lot better luck with from a reliability standpoint particularly in 1/8
I found it: "Hobbywing Xerun Super Capacitor Module". That module looks fine. It is two polymer caps in parallel, they should work well. Just be sure to solder the wires properly, and that the wires are as short as possible.
