Tekin ESC Tuning and Programing
#107
What brake frequency setting gives your the closest to the old software. Since the upgrade i feel like I am always searching for more brake with a 8.5 turn motor.
#108
Could give a brief description of the process to install the HotWire App?
What extra parts if any are needed to connect the tablet to the HotWire?
Thanks in advance for your time.
#110
I'm running a Tekin RSX in my a700 in Stock Class (21.5t Blinky)
Since I have installed the latest update my cars seems so much slower? I have lowered the throttle freq which has made it feel better, but it still seems down on power compared with before?
To make matters worse, I have a few fellow racers I was able to keep behind me comfortably but now my car seems down on power?
Any help appreciated!
#111
#112
Hey Randy - Below are my current settings:
Drag Brake Off
Brake Minimum 0
Active Brake 0
Brake Strength 100
Push Control 0
Brake Frequency 6101
Throttle Min 18
Neutral Width 12
Reverse Speed 100
Throttle Frequency 2007
Reverse Delay 0.76
Torque 10
Timing Profile 1 - Spec Stock
21.5t Fantom FR1 Motor running 35deg end bell timing
The only thing I have changed is the Tekin update, like I said the car just seems low on punch/power. Any advice would be greatly appreciated!
Cheers,
Drag Brake Off
Brake Minimum 0
Active Brake 0
Brake Strength 100
Push Control 0
Throttle Min 18
Neutral Width 12
Reverse Speed 100
Reverse Delay 0.76
Torque 10
Cheers,
#113
Bump,
I am interested in any reply to this too.. It would good to know people's thoughts on how best to approach setup with the new functionality.
Cheers.
Cheers.
#115
Drag Brake Off
Brake Minimum 0
Active Brake 0
Brake Strength 100
Push Control 0
Throttle Min 18
Neutral Width 12
Reverse Speed 100
Reverse Delay 0.76
Torque 10
Cheers,
Drag Brake Off
Brake Minimum 0
Active Brake 0
Brake Strength 100
Push Control 0
Throttle Min 18
Neutral Width 12
Reverse Speed 100
Reverse Delay 0.76
Torque 10
Cheers,
Your settings are ballpark for the team guys running spec turn motors.
#116
Yes, I have reset the end points, throttle etc several times as I also thought this might be causing it, but didn't make a difference.
I'm really not happy with it, it is seriously slower than before the update. I do have another RSX in my 13.5 car that i havnt updated, so i will swap the esc's over and see how the updated one performs in my 13.5t boosted car.
Thank you though, I do appreciate the help.
Cheers,
Cheers,
#117
The update shouldn't make anything slower. I'd like to see a data log from the car if you can email it to me.
#118
Hey everyone, first I have to say that I love my Tekin products and their customer service is awesome!! The question I have is why can I not get my brakes to "bite" harder in my SC5M? I am running with the RS Gen2 ESC and the 10.5T Gen3. When I apply my brakes it will keep the truck free rolling, I thought it was just mine at first. Then I built my buddies SC5M and got him the same setup and it does the same thing. I have tried increasing the brake on the ESC but still same issue. My TLR 22-4 2.0 with the RSX and 6.5t will stop on a dime if needed, at factory settings. Any input would be awesome, thanks in advance guys.
#119
Team Tekin
What is your Brake frequency set at? Also have you made sure to calibrate your Radio and ESC after hotwire update?
#120
Honestly I do not know how to set my brake frequency or how to even look at it. I have re calibrated my radio and ESC. Is the brake frequency done through the radio or is it something that I need the hotwire for? If the case is with hotwire I can order one and check to see if that may lead me to any further improvements.
