Servos - different measurement "mounting tab to output gear"
I have a TLR 22 3.0 with aluminum exotek sero mounts, which allow you to mount th eservo on the front side and the back side.
I also have the Eotek 1580 alum steering rack, in which the bell cranks are a bit longer.
I'm trying to find a full size servo that will fit the Exotek steering rack, with the servo mounted in front of the servo mounts because when motning in the back it's extrmerely hard to fit and tighten.
I know the Savox servos like the 1258tg's are 17mm from mounting tab to output gear, it shows this in some of the TLR 22 manuals for shimming options, the Savox never require shimming and with the Exotek steering rack its required you moiunt the servo on the back side of their servo mounts.. I'm looking for a servo that I can mount on the front side of the servo mounts with the Exotek steering rack.
Does anyone have anywhere I can find such measurements? Servos I'm looking at...
- KO PROPO BSX2 Response HC
- FutabaBLS471SV
Will these fit the TLR 22 3.0 with Exotek steering rack and mount, servo mounted on the front of the munt? Or does anyone one have measurements of many like full size servos>
- FutabaBLS471SV
Futaba has a fair bit of dimensional info on their site if that helps. Click on the servo image. I can't seem to find a 3471, closest is a 3470? An example.
