FlySky FS-iT4 steering wheel issue on controller
Just got the FlySky remote but seems to have a issue. The steering wheel on controller does not bounce back to center when you let it go after turning but instead slowly returns to middle position. If I pull the wheel out like I am trying to remove it, then it will work like a normal rc remote and spring back to the middle position. If i push on it with little force or normal driving it will go back to a being slow and causing issue while driving.
Is this a feature or a flaw?
Anyone?
There's a thread for that radio here: http://www.rctech.net/forum/radio-el...thread-43.html
If you can't find your answer in searching that thread; those are the Flysky fanboys to ask.
Suspended
do you have a steering wheel tension screw if yes loosen it a 1/16 turn at a time.. Other thing i had a rp 11 that i had to put a small washer behind steering wheel in the socket that joined it to the pot
Ill take a look, been finding alot of bad reviews on FlySky so looking into Spektrum now.
