Venom medion won't charge 1-cell lipos.
Well compare the two. Plus use a multimeter. You'll find out which to trust. What ever manufacture, they have different specs like lipos. believe the lipo ratings and minimum voltage and maintenance.
Something wrong with Venom. Take it back to where you bought it and exchange of refund. or the venom not set for 1s lipos. make sure you set the charger, you may have it set for 2s. that why it says low voltage.
3.7 1S lipo don't use a balance board. one cell what there to balance!! I think he didn't set up the charger for 1s.
That is indeed what I was referring to. I use a 2S integrated balancing charge lead, and I can only imagine that when I try to charge my 1S pack when the balance port is in use, my charger senses the 1S voltage where it thinks it should be sensing a 2S voltage.
Purely a theoretical thought process. If jbrow1 isn't using one of those charge leads, then my suggestion holds no ground and I look forward to hearing vemon's response.
Eric & ropes, JBrow says its 1s lipo charging. What happens when your charger set up for 2s, charger is set to 2s, charger check the lipo for 6v. When you charge 1s its looking for 3v. That why its says low voltage, its reading 3v.
Even though you have connection with balance board it wont see that its connected. Its what is set up on your charger. When you balance, you choose to balance.e & set it to individual cells. you monitor its charge. All 1s lipos don't have a balance connector, not needed...
I use a BC6 which is the same charger as the Hyperion. BC6 use on lipos 1s-6s or auto. which I'm confortable, Been using this charger approximately 5-6yrs.
