Replacement ESC for Rustler
#16
If you want something similar to the stock esc get the quicrun 60a. If you want something better than the stock esc get the ezrun sc8.
The vxl 3s esc is only about 70a.
That's the 2 pole motor you have
#17
Still learning how the motor/ESC specs are rated. I assume the 60 amp hobbywing would be ok on 2S but not ok for 3S?
I think I want to stay with something that I can run my 3S battery with.
#19
More I thought about it I figured i already have a 3S battery. I'm going to want to use it from time to time. Probably no point in being cheap now.
If I go with the 120 amp hobbywing will it be good enough for a motor upgrade down the road when the stock one craps out? Or is it best to have a motor/ESC combo paired together (same brand).
#20
If you run 3s definatetly go for the sc8 as its good for upto 4s.
#21
#22
I think Im leaning toward spending a bit more now so I can upgrade the motor later when that dies. Besides the hobbywing 120 amp are there others I should look at?
#23
Have you looked at Castle products? The Sidewinder 3 could be just fine.
