Lipo suggestions please
That's an odd request. Most of the time charge rates are a factor of capacity. So if you have a 4600mah battery you generally charge at 1C or 2C, which would be 4.6 amps or 9.2 amps respectively. There also batteries out there that can be charged at 5C so that 4600mah could be charged at 23 amps. There are some Turnigy's from Hobbyking that are 5C capable, but I have a hard time recommending them at this point since I'm currently having an issue with a new battery and Hobbyking is providing poor customer support.
The Orion 4600 100c packs can handle 5c charges
Super Moderator
Trader Rating: 31 (100%+)
Why the specific 20amp charge rate?
I've got a 4S Turnigy Nano-tech that has a charge rate of 10C. Just have to put together a charging system big enough to try it out
But yea, asking for a lipo that can take a 20A charge rate is pointless unless you provide the mah in question. Almost any 8000Mah+ 2S lipo can take 20A's but a 4000Mah one would be a rare find.....and if we're talking more cells, then your charging system would come into play also.
