Futaba 4PK Throttle Adjustment
Have a 4pk and I am trying to get the neutral throttle to set at 0% on the adjustment screen. I've been trying following the instructions in the manual but it always resets to 35% brake for the neutral setting. Anyone have any ideas? Thanks.
Try doing a throttle calibration. Its described in the manual under Adjuster ADJST
Also be sure idle up is not enabled and check the THMOD setting (Throttle Mode) it could be 70/30
I've tried the ADJST in the following sequence
Barely pull throttle then let back to neutral
Press Jog
Pull full throttle slowly
Pull full break slowly
Press Jog
Press +/-
It says successful after this but never reverts the neutral to true 0% when I turn the radio off then go back into the ADJST screen. Am I not performing the Adjustment right?
Press Jog
Press Jog
Press +/-
what about idel up , did you check that ?
neutral position should be at zero
