Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 03-21-2015, 06:51 PM   #1
ProfessorX's Avatar
Trader Rating: 17 (100%+)
Default Orion r8.1
I just upgraded my regular programmer box not plus to software v1.14 and when I connect the programmer box to the r8.1 to set it up it keeps telling me to upgrade software not sure if it means the programmer box or esc any help would be appreciated thanks
ProfessorX is offline   Reply With Quote
Old 03-21-2015, 09:42 PM   #2
Dan.J's Avatar
Trader Rating: 21 (100%+)
Been doing some digging and I'm starting to think you may need the new Orion Dsbr+ box to make it work on the new R8.1 but I'm not positive. Found this about the other fairly new 1/8 ESC. Maybe this is why you can't get it to work
Vortex R8 Pro X Brushless ESC (220A, 2-6S)
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 04-05-2015, 03:31 PM   #3
maxx90's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to maxx90
Default dsbr
Same prob here. I borrowed the new box same results. But he said he hasnt updated the new box yet. Imma call orion tomorrow.
maxx90 is offline   Reply With Quote
Old 04-05-2015, 05:15 PM   #4
Dan.J's Avatar
I downloaded the latest software on my PC from Orion and was able to update the box and now everything works fine using just the box or my PC to make changes. If you are running a Orion motor you can hook the programmer into any of the sensor ports on motor and ESC, if you are pairing the Orion ESC with a different brand motor I believe you need to unhook the sensor wire from the motor and then plug the box into the ESC to get it to hook up. Side note got a chance to play with the R8.1 a bit yesterday paired with a Orion VST2 1900KV and so far so good, lots of power/ nice brakes and smooth like I was expecting.
