Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 02-11-2015, 04:59 PM   #1
Mudcat981's Avatar
Questions?? Charging at 1C, 2C, 3C, does it really matter?
I was wondering the benefits of charging a LiPo battery at higher than the recommended 1C rate (ROAR rules only allow 1C rates, but local races anyhting goes). Put aside all safety stuff and life of a battery and such. What is the benefit of charging at a higher rate?
Heare are some of the reason I have heard the higher rate will provide more:
1) punch
2) more volts
3) last longer
4) charge faster <-- this I believe.
Is there any truth to any of the above or is there something else? If it is only the rate a battery charges, then if you have plenty of batteries why damage a $50-150+ battery?
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 02-11-2015, 05:06 PM   #2
RC Juice's Avatar
Trader Rating: 140 (100%+)
Mainly #4, it charges faster. It definitely does not make batteries last longer, and you can get a little more punch for the first part of the pack when it is charged at a higher rate.
RC Juice is offline   Reply With Quote
Old 02-11-2015, 10:59 PM   #3
Super Moderator
Grizzbob's Avatar
Right, but more than likely, even ONE bump against a barrier or other silly mistake in a race will make that miniscule extra performance meaningless. Which is why I stick fairly closely to 1C(I might do 1.5C if I need to cut down the charge time), I KNOW I'm not a good enough driver to take advantage of that, so for me it's just a waste of a good battery to push it that much....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
