Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-28-2014, 08:14 AM   #16
Geezatec's Avatar
Lipo's not like NiMh. Minimum voltages on lipo are 6v, 3v per cell. Most models they have a cut-off voltage on ESC. To make it simple set up cut off @ 6.2v or any type of glitch on model, Stop and recharge. Basic lipo maintenance.
Geezatec is offline   Reply With Quote
Old 12-28-2014, 09:00 AM   #17
longuylander's Avatar
I charged the battery to 7.6 volts, and it seems happy enough. I didn't want to try to fully charge it as I cannot run the car and that Onyx charger does not have a discharge function. Only time will tell if it was a fluke or if the battery is going to discharge on its own again.
longuylander is offline   Reply With Quote
Old 12-28-2014, 10:25 AM   #18
Geezatec's Avatar
Like you said the onyx 150 is cheap. you don't want to fully charged. You want 6v or 3v per cell is good enough. Then use cheapy onyx to 4.2v per cell. Purchase better charger and learn the lipo chemistry. Interesting hobby!!
Old 12-28-2014, 08:48 PM   #19
http://www.batteryuniversity.com/
min voltage is 2.8v, not 3v . This is min, not recommended if you want it last .
You can go below that & still have a usable batt
You can leave the batt fully charged for 9months+ & still have a usable batt (dont ask how I know)
Or you can follow correct batt procedures & still have it fail in 6 months
If it works, keep it as a spare/practice/fun/basher batt.
A usuable batt is not the same as a race spec batt
Also, get a low voltage beeper, thats the best $10 you'll spend. Stop AS SOON AS IT BEEPS , as voltage can drop rapidly after that.
1101 is offline   Reply With Quote
Old 12-29-2014, 01:27 AM   #20
Many different slight variations to lithium cells.
The current Lipos we are using do not like to go below 3.2V per cell. And IMO from the testing I have done anything below 3.5V hurts cycle life considerably.
frozenpod is offline   Reply With Quote
Old 12-29-2014, 08:29 AM   #21
Geezatec's Avatar
There a reason why I say 3v. 2C to 6C lipos using balance charger. You discharge lipos. One cell on a 2C lipo are different. no lipo are the same. One lipo cell could discharge to 2.8v the other 3.2v avg 3v. Up to 6C avg will be 3v. Try your balance charger with individual cell readings. You can see. Lipos & LiFe batteries much difference than NiCd & NiMh. Lipo with punch and less weight hobbyist looks at, especially airplanes. We came along way from beginning. lipo had the problem of fire and explosions. Knowing the science of lipos make it easier to understand.
Old 04-27-2017, 02:55 PM   #22
Default Build tough with Chevy stuff
I just use a cheapo charger and a lower grade venom battery (I only use venom batterys) and if it craps out I will just buy a new one. I always thought more batterys of a lower grade is better since if one goes out its just a twenty dollar loss instead of a sixty dollar loss.
Meme is offline   Reply With Quote
Old 04-27-2017, 04:52 PM   #23
gigaplex's Avatar
Or it could be a really expensive loss if the battery burns down your home.
gigaplex is online now   Reply With Quote
Old 04-27-2017, 05:00 PM   #24
the rc guy's Avatar
you never take any lipo to 3volts a cell not good info they should be stored at 3.72 volts a cell and no less.. to revive a lipo try using nimh mode watch battery voltage go up to around 3.70volts a cell then use lipo balance mode.. it does not matter how many C it is..lipos are all the same ..100c or 2c..still same inside..
the rc guy is offline   Reply With Quote
