iCharger 308DUO Power Supply Choices
#47
#52
My ps checks 12.14v on the output but the 308duo shows that it's 12.326v as it's input voltage. Not sure why the difference unless my dvm is off.
Charging 1 4s pack at 30a it showed as high as 17.181v @ 24.73a = 425w
Charging 2 4s packs at 30a it showed 16.66v @ 18.87a & 16.59v @ 18.97a = 314w on each channel
This test doesn't change anything for me personally as we don't charge that high anyway nor do we ever charge 2 4s packs at the same time but it does change my recommendations for power supplies going forward depending on the end users requirements.
#53
Your results appear to confirm that charger power scales reasonably well with power supply voltage.
Thanks for taking the time to test and post the results.
#54
So it seems like most of these new high power chargers cut power output a bunch when using a 12V supply even if the 12V supply has plenty of amps. Are they all like this or is there a certain brand that can output more power on a 12V supply? My supply is 12V 75amp 900watt and works great for what I'm using it for but if I step up to a icharger or powerlab it looks like it will only do so much being 12V. Interesting thread.
#58
I place my order for the 308 duo yesterday. i still have not sorted out what i will do for power supply. I'm not entirely comfortable with the making my own even though it would be cheaper. i also don't like the way those computer supplies look. lol i wouldn't mind seeing some pictures of some of these charging station set ups.
I currently race off road 10th scale and mostly run shorty packs i will probably get a 1/8th scale in the coming months so being able to charge 4s will come into play. as much as i don't like the look of it the shuur speed power supply seems like it would do the job and is pretty inexpensive. is that an accurate assumption?
I know many of you use this charger to its full capacity and have 24v PS to meet that need. i will more than likely never charge above 15A on 4s 5000mah or 6000mah lipos.
thanks for any advise.
#60
