Team Orion Servo Problem
Having problems with a Orion 2612 servo(ORI68012). I just purchased this used from a fellow rctech member and only got about a lap around the track when I immediately noticed something wrong. Once the servo is run for a minute or so it slows drastically, then you slowly lose all steering. Once you let it sit for a couple seconds and try to steer it works for a brief second then goes back to non-functioning. I've already tried another servo in its place and works pefectly fine. Is the servo no good?
Kyosho RT5
Servo- Orion ORI68012
Radio- KO ex-10 Spektrum
esc- R10 Pro
Motor- Orion Vortex Pro 7.5
http://vid464.photobucket.com/albums...psmcox67ru.mp4
Kyosho RT5
esc- R10 Pro
Getting hot and dying off?
Any binds in your steering linkage?
Its acting like its getting hot and dying off but the servo isn't hot. Like i said I put another servo in its place and worked perfectly fine. The original servo that I used before the 2612 was another orion servo, the vds-2015 but I needed it for my 1/8 so I purchased the 2612 used from a fellow member. with the vds-2015 in the truck it operates fine so I know its not the steering linkage because all I did was swap servos.
Added video
you can see the servo slow after steering for a few seconds. On the track I got around a few corners and noticed something wrong. with the tires on and the weight of the truck it happens quicker.
Added video
That thing is toast.
