Keeping stuff out of the fan on an rx8
anyone come up with a way to keep things out of the fan on the rx8. Twice I have something come off the track and get stuck in the fan causing it to stop running. Just trying to think of something to cover it with.
try insect screen for windows. glue/tape it to top or try to cut holes where the screws for the fan are
Sorry Hoese that's not correct. All fans should be installed to blow air down over the heat sink of the esc. Definately not pull air up and away from the heatsink. This is the intended installation of the fan. The tekin manual found here http://www.teamtekin.com/assets/tws_manual_rx8gen2.pdf also states the same under 'fan installation'.
unless you run an unusual configuration, don't use a fan on the RX8
you can monitor the temps with the leds and the esc will shut down if it's too hot anyway
just cut some vents in the body
