Charger can charge current of 10 Amps 2 batteries at once?
hello
I have a question, I do not understand. Charger can charge current of 10 Amps 2 batteries at once? or only one battery.
orion dual touch dual 10 amp its about 225 250 price wise but its ac dc so no added power supply needed or the i chargers are great. that would be my 2 choices.
Keep in mind too that you will need a power supply that can provide that total amount of amps as well, so if you want to charge two batteries at 10amps you will need a power supply that can deliver 20amps, preferably more, or for 2x20amps you would need a 40amp+ power supply.
Hope this helps.
Specifically which charger are you asking about? There are a lot of chargers that can charge two batteries at 10amps each, but you need two output channels to be able to do that. Something that looks like this one: http://hobbyking.com/hobbyking/store...e_charger.html
Hope this helps.
Hope this helps.
