Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 12-03-2014, 01:01 PM   #61
Originally Posted by Slapmaster6000 View Post
Howard, just for show, I tested a motor every 5* starting at 25* just to see where the amps went nuts.
25* @ 0.9a
30* @ 1.2a
35* @ 1.4a
40* @ 1.8a
45* @ 2.3a
50* @ 5.5a
That is what I have seen on the Fantom Dyno also. Once you get passed 45 deg. The rpm will jump with the amp draw. The bottom end torque also goes away though. Something you cannot see with this device.
www.norcarracing.com
NORCAR @ The Gate
old_dude is online now   Reply With Quote
Old 12-03-2014, 02:04 PM   #62
DesertRat's Avatar
Well, mine just showed up in the post, time to unsolder every motor I own.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 12-03-2014, 04:12 PM   #63
EDWARD2003's Avatar
Enjoy! Make sure the screws holding the motor mount are secured tight, I had one come loose. You don't want a screw rattling around on top of the circuit board.
EDWARD2003 is offline   Reply With Quote
Old 12-03-2014, 07:08 PM   #64
Madulla's Avatar
Can you test with the motor connected to the esc or would that damage the esc?
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 12-04-2014, 12:05 AM   #65
Can the Gforce be used to set timing on a motor????
THEBIGBULL is offline   Reply With Quote
Old 12-04-2014, 08:40 AM   #66
b20btec's Avatar
I do it all the time but to verify timing. I'm sure others will disagree so I'm not going to say it's safe but I've done it on all of my cars with 3.1 esc.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 12-04-2014, 09:42 AM   #67
DesertRat's Avatar
Things I've learned:
The 40 degree mark is 62 degrees of timing on a Tekin 17.5, which means 17 amps when free spinning. I dialed it back to 45 degrees and only 3 amps free spinning amp draw on the checker. Maybe that's why that thing was such a dog.
My LRP X20 17.5 is actually advanced some 5 degrees past the claimed number on the insert, but it had one of the least variance between the three poles. Even so, it was drawing less than 2 amps at 40 degrees advance showing on the meter.
All timing is not created equal, and older motors have much less timing built into them than new ones. My old Trinity Duo 17.5 was timed at 45 degrees with the endbell cranked to the stop, but spun pretty high and only drew 2 amps on the checker. Setting my Orca RX3 to 45 degrees drew over 6 amps, and it didn't seem happy with it. The Orca RX3 seems to want less than 40 degrees.
On the other end of the spectrum, my Team Powers 17.5 only drew 6 amps with 60 degrees of advance. It seems the wind and core construction of the motor counts for more than I thought.
Modified motors get so much more out of a given amp draw. 2 amps of draw on my 4 turn gives me over 35,000 rpm.
Check your bearings. One of mine was gummed up with track detritus, and you never would have guessed by looking at it.
Old 12-04-2014, 09:51 AM   #68
DesertRat's Avatar
Based on what I know of brushless ESC's it should be okay, but I will unsolder my motor a bunch of times for the $200 I would be risking by powering it up. The MOSFETS in ESC's are tough and hard to overdrive, but it's just not worth the risk. The only check I could recommend in good conscience with the car ESC hooked up would be checking the hall effect sensors. Just unsolder the wires to do powered tests, it's not hard or time consuming.
Old 12-04-2014, 10:04 AM   #69
lpittman's Avatar
Some great info here. Keep it coming folks! Looking forward to getting mine.
Luke Pittman
WCICS Website/Social Media Director
XRay/RC America MOTIV RC PROTOform ORCA RC Avid RC ProLevel RC Max Power America SANWA Apex RC/ProSpec
lpittman is offline   Reply With Quote
Old 12-04-2014, 06:38 PM   #70
EDWARD2003's Avatar
Since this motor checker generates numbers under no load, is there anything we can attach to do to produce a load? Have the motor connected to a.......?
Old 12-04-2014, 07:22 PM   #71
the old competition electrics turbo 30's had a fan to check amp draw. you attached the fan to the drive shaft and powered it up. might try that. as long as the fan is balanced and in a shroud. i watched a guy cut himself pretty badly from a fan blade coming off while he was holding it. its a good idea but can be dangerous if not done right. maybe make a mount to hold the motor and cover the fan. dont know if it would work with this setup.
dragonracing is offline   Reply With Quote
Old 12-04-2014, 08:14 PM   #72
EDWARD2003's Avatar
I guess I could re-position the motor to face the opposite direction and place a fan on the end. To contain the fan from damaging me or others, I could simply get a tupperware box, cut a round hole on the side and slide the motor shaft through. Place the fan blade on, seal the top, and power it up.
Old 12-04-2014, 08:27 PM   #73
In the passed I have used a prop from one of my old planes to provide load.
Not as good as a brake dyno but better than no load.
DamianW is offline   Reply With Quote
Old 12-04-2014, 08:39 PM   #74
that could work. or a ducted fan housing. anything to keep the fingers protected. the guy i mentioned needed stiches. it was pretty deep.
Old 12-05-2014, 03:16 AM   #75
howardcano's Avatar
Trader Rating: 35 (100%+)
Without a method to vary the load and measure the torque, this won't give much useful information.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
