Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 11-25-2014, 08:48 PM   #46
DARKSIDE's Avatar
I love this thing...I havent put it down since Sunday...well worth the $$$$ and love having the simple things that make life a little easier...
Thanks EA
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Summer Slam
July 28-30
DARKSIDE is offline   Reply With Quote
Old 11-26-2014, 04:10 AM   #47
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Slapmaster6000 View Post
I just picked up one of these units. It's the one the reads to 50*. I have decided that I will make readings at 40 and 45 as well as 50, and if I have to, I can estimate 55 and 60. Sure it would be nice to actually see it, but I will manage.
Everything I race is 1s, so the voltage tested at is double. It won't run on 4.2v. Again, I will manage. EA: do you think the KV and Amps are linear to the voltage input? Or do KV and amps follow a different curve in relation to voltage? Its all relative, just curious.
Hi Brian,
I hope EA doesn't mind me chiming in here!
Extrapolating kV and current draw past 50 degrees is a challenge. The results are very non-linear; everything really skyrockets at higher timing settings. I don't know what the curve is, but maybe someone here can give us the closest mathematical approximation to it (total guess: tangent?).
kV does not change with voltage. Half the voltage will give you half the RPM, which is the same kV.
Strangely enough, free-running amp draw also doesn't change much with voltage. Frictional and hysteresis losses are approximately linear with RPM, so 1/2 voltage will give about 1/2 the power loss. Since the voltage has already been halved, the current will remain the same to give 1/2 the power loss.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 11-26-2014, 01:13 PM   #48
DesertRat's Avatar
Well I hope this thing will tell me some useful information, because I just ordered mine. Maybe it will change how I run all of my stock motors, which is crank the timing to the stop and gear for lap times at mid-race.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 11-26-2014, 02:13 PM   #49
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by howardcano View Post
Hi Brian,
Howard,
Your information never bothers me at all! You have more knowledge about this type of stuff than just about anyone in RC so your input is always welcome! Thanks!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 11-27-2014, 09:47 AM   #50
Mikkel_R's Avatar
Hello,
Does anyone have an idea what the maximum current draw of a 13.5 with no load at max rpm and timing would be?
Thanks Michael
Mikkel_R is offline   Reply With Quote
Old 11-28-2014, 10:55 AM   #51
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Ah, I feel like I am getting my "geek" on with this tool. I've already filled up several sheets of paper with recordings and formulas. Howard, thanks for response with big words! I wanted to test that answer with some data on my end and wondered how I could do that. The VX1 records max rpm. Not real convenient to do, but I did it. Took 3 samples at 4.1 volts. Put an Amp meter inline on the battery. And you are absolutely correct, that amperage is relatively unchanged from 4.2 to 8.4. From my residential wiring days and the classroom training, they taught us that as voltage increases, amperage decreases if the load is fixed. Its the reason that heat or hot water run off of 240v as it will operate more efficiently and on smaller gauge wire. Apparently this doesn't carry over to brushless motor operation.
So I had a motor display 2783 KV on the GForce @ 8.3v. If I were to correct that for 4.2v, I would multiply the KV by 1S voltage, you get 11688 free spin rpm.
From the VX1, I get 9730 max rpm on that same motor. So divide max rpm by pack voltage (4.1v) and I get 2373KV.
The amperage is the same from the GForce at 8.3v and the from the amp meter at 4.1v
So there is a slight difference in KV rating. Of course where I am going with this is to see if I can go from motor A to motor B with a little calculation and come up with identical performance on the track. I know that won't happen, but its worth a shot.
I'd like to see a power or a hp #. Just because you see a big KV # doesn't mean the motor makes more power. Wattage (volt x amps) is not going to reveal anything useful, is it?
So far, I've been able to identify a bum bearing and see the results improve. I've played with rotor to sensor shimming and witnessed the changes. I guess my goal would be: gather some data, calculate that this motor with this timing with this gear should be optimal. I'm open to any suggestions at this time.
I'll take my pocket protector off now.
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 11-28-2014, 11:04 AM   #52
Howard, just for show, I tested a motor every 5* starting at 25* just to see where the amps went nuts.
25* @ 0.9a
30* @ 1.2a
35* @ 1.4a
40* @ 1.8a
45* @ 2.3a
50* @ 5.5a
Team Roche USA
Old 11-28-2014, 12:44 PM   #53
howardcano's Avatar
It's always fun to talk shop with you, Brian!
It sounds like something is just not right with the motor checker when running at low voltage. (EDIT: no, see below) For comparison, I just ran a ThunderPower 17.5 (timing=38 indicated) from 1s and 2s batteries. The ESC was a Novak Edge, using a Novak Smart Boost as the regulator on 1s, and the internal regulator on 2s. Here's my data:
Voltage RPM Calculated kV
3.815 9930 2603
7.57 19410 2564
As you can see, the kV was virtually unchanged: about 1.5% different, most of which I would attribute to the voltmeter accuracy. Your numbers vary by 17%, which is a little more than I would expect. But I'm not sure how accurate your voltage measurements are.
You are right, measuring power consumption at no load is of very limited value.
EDIT: Duh, silly me, the motor checker runs in sensorless mode, and you were using a VX1 for 1s testing, which I'm guessing was running in sensored mode. That explains the difference in kV. You'd get the same kV if you set the motor timing to zero.
Howard Cano
Old 11-28-2014, 01:26 PM   #54
howardcano's Avatar
25* @ 0.9a
30* @ 1.2a
35* @ 1.4a
40* @ 1.8a
45* @ 2.3a
50* @ 5.5a
The current and the RPMs both go nuts together, too... kind of like being married.
I did a quickie check of your current data. It has a reasonable fit to my guess of a tangent up to 45 degrees, but no higher.
Howard Cano
Old 11-28-2014, 06:50 PM   #55
big al's Avatar
Hey guys, I've long wondered what effect rotor shimming has on overall power. I realize that this thread is for the motor checker, but this thread clearly has a higher collective IQ than the majority of other threads, and I would like to capitalize on this. I've always just pulled the necessary shims to allow the rotor to find its own electrified center. Is this wrong? Any info is appreciated!
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 11-28-2014, 10:36 PM   #56
All I can say at this point, nothing seems to be consistent. I went through a pile of 13.5's today. I would make some recordings to baseline, then make some alterations and retest. Some improve, some not and I am not even sure that I am seeing different numbers as a reduction. At this time, I am just fooling around and making numbers. I don't know if I am making good numbers, bad numbers or just different numbers. Until I can come up with a solid load test, I won't know if I am making forward progress. I can pop in a 12.3 rotor and get a higher KV rating then a 12.5 rotor. But I know that 12.5 will let me pull another tooth and be faster at the end. Yes, a 12.3 rotor should produce a higher KV, but is it making more power? Some motors I have magnetically centered the rotor and then moved the sensor board closer. Some improve, some don't. I have not come up with a cookie cutter formula for building motors. So Big Al, sorry buddy. I don't have that answer.
At least not yet.
Team Roche USA
Old 11-29-2014, 01:39 AM   #57
RC MARKET's Avatar
can choice SKYRC with bester price
RC MARKET is offline   Reply With Quote
Old 11-29-2014, 07:26 AM   #58
Trader Rating: 17 (100%+)
At least not yet.
I have not been able to make a 12.3 rotor (in our current motor) make more power on either my Turbo Dyno or my Fantom. After several tries, I scrapped the idea and moved on. 12.3 = more RPM and more efficiency, but not more Torque or Watts.
As always, YMMV.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-29-2014, 04:28 PM   #59
big al's Avatar
At least not yet.
No worries, Brian! I'm just trying to broaden my brushless horizons. I sometimes miss the old brushed days... digging in to my secret stash of brushes, and polishing comms.
I'll eventually make it to the community center, too many packages to deliver this time of year!
Old 12-03-2014, 05:12 AM   #60
Ciao AE,
i sent you a pm
Max
Touring: WRC STX
F1: WRC F-ONE 200 and 180 mm
ESC:Viper VTX10R; Motor: too many; Radio: Sanwa MT4
Don't follow me.... at the end of the straight there is the hairpin and my wall.....
mtaddei is offline   Reply With Quote
