Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 01-25-2015, 10:42 PM   #166
DesertRat's Avatar
In defense of the Motor Checker numbers, I checked a Trinity D4 13.5 on the device and found it off by just as much (number on the endbell vs reading) so it may just be that Trinity is off. The endbell read 60 degrees and the checker read 48 on the 13.5.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 01-26-2015, 12:03 AM   #167
Cridd's Avatar
Trader Rating: 16 (100%+)
my d4 was off by 9 degrees, set at 60 read 51 on motor checker.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-26-2015, 10:26 AM   #168
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Thanks for the feedback guys!
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-26-2015, 04:37 PM   #169
dont think itrs the same
articsilber323 is offline   Reply With Quote
Old 02-04-2015, 07:43 PM   #170
Trader Rating: 168 (100%+)
Originally Posted by godzukihop View Post
Just got my GFORCE MOTOR analyer and have been playing around with it, but had a few questions. Can anyone advise on good or max #'s for amp draw, RPM, timing and noise. I am in need of help with a 25.5 Novak for VTA.
Did you ever get a answer for this, as I would like some idea on numbers as well, seems the thread has gone technical, so if you have any info, please share with some of us
We go to have fun, that is why we go
Grand Cities R/C Club member
Ecrt.5 on 4s pack= 82 mph
Ecrt.5 on 6s = broken parts
Troubles Dad is offline   Reply With Quote
Old 02-04-2015, 07:59 PM   #171
patorz31's Avatar
So how high should the free reving amp draw be for a 17.5?
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 02-04-2015, 08:19 PM   #172
DesertRat's Avatar
For a 17.5 2-2.5 amps seems to be a good spot. For a 25.5 I remember seeing a thread a while ago where a VTA racer was setting the timing with a DC current meter, not an actual motor checker, and they said that just under 2 amps seemed to work best as the amp draw really began to spike with any more.
Old 02-04-2015, 09:16 PM   #173
bru00z's Avatar
Originally Posted by DesertRat View Post
For a 17.5 2-2.5 amps seems to be a good spot. .
I know in offroad that lows amps is very slow. I tested one of my team powers 17.5 and it draws 10amps at about 40' timing free revving. I tried it down to about 4 amps and was way off the pace in the car so hate to think what 2 amps would be like.
Motor comes off between 60-70 celsius and have about 1200mah battery drain for a 5 minute race so all seem good and acceleration and top end is right up there. Also confirmed with a friend who runs R1 wurks 17.5 and his draws 10 amps too.
Alex
Team Associated / Ace Hobbies / Proline Australia
bru00z is offline   Reply With Quote
Old 02-05-2015, 07:56 AM   #174
patorz31's Avatar
10 amps at free rev seems awful high. I was thinking 2.5-3 amps.
Old 02-05-2015, 08:10 AM   #175
b20btec's Avatar
Anything lower than 10 amps on my 17.5 team powers for onroad I might as well race it in a 21.5 class. We run min quals and main and with this setting I hardly have fade. I'm logging my rpm after each run and the team powers motor is happy at 17,600-18,300 max rpm.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 02-05-2015, 09:04 AM   #176
DesertRat's Avatar
I have a Team Powers Actinium as well and when testing it on my Motor Checker it had an unusual ability for a 17.5, running it at the lock, which was about 60 degrees of timing, it spun a LOT of RPM and didn't seem to hurt its low-end. Also, at 60 degrees my motor was only drawing about 6.5 amps, not 10 or even 20 amps that my Tekin 17.5 drew at 60 degrees of timing. Each motor is different, if I had tried to run my Orca at 60 degrees it probably would have just given up, it wanted only 32 degrees and any more made it completely lose its low-end.
Offroad is a different animal, mid range and "wind out" on the top end is much more important because low-end grip is limited. You're also on the throttle proportionally less than onroad, giving the motor time to cool in the breeze. If you get the best results cranked, run it cranked.
This is a highly inexact science, and the Team Powers motor has been the oddest one I have tested, but it's a great motor performance wise and responds well to extra timing.
Just a little anecdote though: My Team Powers 17.5 draws 50-100 milliamp hours MORE power to run 50 laps of 1/12 scale than my Trinity 13.5 does to run 54 laps of 1/12 scale... in the same 8:05 range. There is some serious efficiency difference here.
Old 02-05-2015, 09:10 AM   #177
Originally Posted by EAMotorsports View Post
I have one left in stock at www.teameam.com I am expecting another large order of them next week. I am the US Distributor for Gforce.
EA
Just took the plunge. Looking forward to seeing if it's worth the beating I'll get when the financial officer sees the credit card bill!
Byrdman
MCKNBRD is offline   Reply With Quote
Old 02-05-2015, 09:41 AM   #178
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
Byrdman
Thanks. I'lll get that out tonight.
I got a fresh batch in for anyone needing one.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 02-05-2015, 10:00 AM   #179
Johnny Wishbone's Avatar
Originally Posted by Johnny Wishbone View Post
Hey Kraig, I'll have to go back and check, but when I did a quick timing check on my mod motor (just did one), the timing readings where very whacked. Not even close to the marks supplied on the motor. The motor on track worked ok so I don't think it was the motor, but didn't get a chance to second check on the meter. The other thing that worries me a little is when doing the timing check, a mod motor spins very high in the timing check mode. I don't think I would ever free rev a mod motor that hard.
Not sure if that answers your question but that's what I've found so far, maybe others are doing mod motors differently though.
I'm going to recant the previous statement. I finally got a chance to check the mod motor in question, and the meter was correct and the motor was very much out of adjustment, a very badly misplaced timing sticker, no less.
It also seems that when a mod motor timing is being checked, it does it faster than when a 17.5 is being checked, so there is less spin time on the rotor, so less likely to over rpm and explode.
Seems to be a pretty decent tool.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-06-2015, 05:47 AM   #180
Cool
EA
Awesome! Thanks!
Now I just have to figure out what to do and how to tune the Novak 25.5s I have...
Byrdman
