Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 01-16-2015, 06:03 AM   #151
bigcracing's Avatar
Trader Rating: 32 (100%+)
I tried superior hobbies and there web site is not avalible?
bigcracing is offline   Reply With Quote
Old 01-16-2015, 06:05 AM   #152
godzukihop's Avatar
Trader Rating: 31 (100%+)
http://www.stormerhobbies.com/
JOHN's MOBILE RACEWAY | 180 RACEWAY | Jackson RC Track
Murnan Modified because HP is intoxicating!!! | VP RACE FUEL |
G-FORCE HOBBIES | Fordham Hobbies | ASHFORD HOBBY | TEAM CAMDEN
RC AMERICA / XRAY / HUDY / TEAM POWERS
godzukihop is offline   Reply With Quote
Old 01-16-2015, 06:13 AM   #153
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
Who has the analyzers in stock?
I have one left in stock at www.teameam.com I am expecting another large order of them next week. I am the US Distributor for Gforce.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 01-16-2015, 08:37 AM   #154
b20btec's Avatar
Originally Posted by EDWARD2003 View Post
I do have the option of bolting on more weight. The maximum the dyno can handle grams.
What's the maximum weight the dyno can handle in grams? I have one on order and I was told they're out of stock on the flywheels.
Maybe you should start a user thread on the eagle model dyno.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 01-21-2015, 12:50 PM   #155
Wildcat1971's Avatar
Trader Rating: 79 (100%+)
can this check the resistance of the stator?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-21-2015, 03:36 PM   #156
howardcano's Avatar
Trader Rating: 35 (100%+)
No. A decent milliohmmeter costs much more than the Analyzer. Here is an example:
http://www.gwinstek.com/en/product/p...&mid=80&id=210
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-21-2015, 03:50 PM   #157
so, I would need something like this http://www.racersmeasurementsystems....System-MMS.htm
Old 01-21-2015, 04:22 PM   #158
howardcano's Avatar
For lower-accuracy measurements, that should do nicely. (I didn't see any spec for accuracy in the link you provided, so don't expect to be able to compare numbers taken with two different devices. If you are just using it for comparison purposes on your own stators, then that's fine.)
You'll want to check the alligator clips that come with it, to make sure the two jaws on each one are isolated from the other. If not, then add some clips to make it a true 4-wire (Kelvin) connection.
You'll also need a thermometer to measure the stator temperature, then apply the necessary temperature correction to the readings. Copper resistance increases substantially with increasing temperature.
Howard Cano
Old 01-23-2015, 11:54 AM   #159
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Anyone have any experience with this unit using modified motors? I am curious if it is worth it for that type of application.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-23-2015, 12:33 PM   #160
DesertRat's Avatar
It will spin up a modified motor and give amp draw and timing readings just fine. Mod motors hardly draw anything in free-spinning mode, and you don't need to turn it up all the way...
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 01-24-2015, 01:15 AM   #161
It will run mod motors fine.. My drag motors which pull a lot of amps free rev did smoke the pc board but alittle solder and braid fixed it.. My motolyser didn't fair too well and it's in Sweden now for repair..
speedpro1 is offline   Reply With Quote
Old 01-25-2015, 06:54 PM   #162
EDWARD2003's Avatar
One of the screws holding the motor mounts vibrated loose and shorted out my motor checker. You might want to check the screws and make sure they are tight.
Do you think it's feasible to send it back? Would this be considered a defect?
EDWARD2003 is offline   Reply With Quote
Old 01-25-2015, 08:58 PM   #163
Super Moderator
Kraig's Avatar
I am just wondering if the extra tuning options (sensor alignment, etc) would make sense in a mod motor.
Old 01-25-2015, 10:06 PM   #164
DesertRat's Avatar
Well, i found that the timing marks on my 4.0 turn D4 were off by a lot and I thought 23 degrees of timing was a few less than it should have, also the sensor was off just as much as my stock motors, but Mod makes up for inconsistencies in brute force. If all I raced was Mod, i wouldn't have bought the motor checker.
Old 01-25-2015, 10:23 PM   #165
Johnny Wishbone's Avatar
Default Mod motors
Hey Kraig, I'll have to go back and check, but when I did a quick timing check on my mod motor (just did one), the timing readings where very whacked. Not even close to the marks supplied on the motor. The motor on track worked ok so I don't think it was the motor, but didn't get a chance to second check on the meter. The other thing that worries me a little is when doing the timing check, a mod motor spins very high in the timing check mode. I don't think I would ever free rev a mod motor that hard.
Not sure if that answers your question but that's what I've found so far, maybe others are doing mod motors differently though.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
