Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree4Likes
Old 01-13-2015, 05:37 PM   #136
DesertRat's Avatar
Originally Posted by noline View Post
Can you tell me what all did you do to get your sensor realignmed?
I just re-position the sensor board by slightly bending the tines the support it.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 01-13-2015, 06:28 PM   #137
EDWARD2003's Avatar
Eagle Racing Dyno computer setup.
EDWARD2003 is offline   Reply With Quote
Old 01-13-2015, 10:16 PM   #138
All the expensive rc equipment money can buy, but has a computer from 1992. Sometimes it's all about the priorities. LOL I kid, nice setup there.
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 01-13-2015, 10:32 PM   #139
DesertRat's Avatar
I'm less interested in the Clinton Era computer and more curious about why Ed wants the dyno results of what is clearly a Black and Decker drill motor.
Old 01-13-2015, 10:41 PM   #140
EDWARD2003's Avatar
Hey, you fools! That's not my setup. It's just a photo to give you a visual of what it can do.
My computer runs on MDOS.
Old 01-13-2015, 11:22 PM   #141
Cridd's Avatar
Trader Rating: 16 (100%+)
I think you guys are over-thinking it. The real advantage of the motor checker is not in making sure each sensor is degree-perfect, because if they're all pretty close (for instance, after adjusting my sensor board on its mounting screws it now reads A:44 B:46 C:46) its close enough. The real advantage you will get in performance is in finding the "sweet spot" in the timing. For 17.5 motors this is about where it draws 2.0-2.5 amps, and for 13.5 about 4 amps. After setting my motors to this number and finding a gearing where the motors stayed cool, lap times dropped on punch out of corners. That's the advantage of this tool, in my opinion.
When testing for amps, is throttle turned all the way up to full red Level 8?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-14-2015, 08:17 AM   #142
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
For anything over 10.5T, yes.
_____________________________________
Earl Towson
Team RC America - Xray USA - Hudy USA - Motiv RC - Max Power - Gravity RC - Prolevel RC - GRIPWORKS RC
WCICS.ca club rep. www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 01-14-2015, 08:21 AM   #143
Hilarious!
damo is offline   Reply With Quote
Old 01-14-2015, 08:32 AM   #144
Mikkel_R's Avatar
I de-soldered the sensors and moved them.
Sky RC are doing a similar Dyno to the MD2
http://www.mcmracing.com/en/home/729...dyno&results=1
Mikkel_R is offline   Reply With Quote
Old 01-15-2015, 03:30 PM   #145
bigcracing's Avatar
Trader Rating: 32 (100%+)
Who has the analyzers in stock?
bigcracing is offline   Reply With Quote
Old 01-15-2015, 04:46 PM   #146
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Superior Hobbies had a few left when I ordered from them yesterday.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 01-16-2015, 03:48 AM   #147
EDWARD2003's Avatar
Eagle Racing MD2 Motor Dyno results for a R1 Wurks set at 40 degrees using G-Force Motor checker. The load was a 120.3 g weight with a diameter of 40.00 mm. Using a 7.4 lipo battery, and a LRP Flow ESC. The information you see here is the maximum values. There are many other parameters you can check out. Pretty neat unit.
Old 01-16-2015, 04:07 AM   #148
howardcano's Avatar
Trader Rating: 35 (100%+)
That small of a flywheel isn't going to give very much accuracy; the spool-up time is too fast, making the data points spaced too far apart. At least ten times the weight would be much better.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-16-2015, 04:52 AM   #149
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Random question for compassion. How much did the fantom dyno flywheels weigh from back in the day? I remember one of the guys at the track I was at had both aluminum and steel fly wheels.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is online now   Reply With Quote
Old 01-16-2015, 04:59 AM   #150
EDWARD2003's Avatar
I do have the option of bolting on more weight. The maximum the dyno can handle grams.
