Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree1Likes
Old 12-18-2014, 10:51 AM   #91
JayL's Avatar
also the Asymmetry measurement is one of the best features, You can really feel it when you drive if you have a good one
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 12-18-2014, 11:30 AM   #92
Originally Posted by DesertRat View Post
I severely doubt that a software update will allow the GForce unit to give you the amp draw of each phase, I think that would require a hardware change and up the price as the digital ammeter is probably a good chunk of the cost. I think the ability to measure the individual phases will remain the advantage of the Motolyser, and if people are hard-core (like oval guys, who traded in their sanity for an extra tenth a long time ago! ) it may be worth it.
As for the motor I tested, it was a Team Powers motor, not an R1. I have also tested my Tekins, Trinity Duos, LRP x12 and X20, and others and all required a little "massaging" and centering of the sensor board to get it closer to perfect.
Thanks As a recovering oval guy, I'm still searching for my sanity - it must have turned right sometime while I was busy turning left.
John Wallace2 is offline   Reply With Quote
Old 12-19-2014, 03:09 PM   #93
Jethroz's Avatar
Trader Rating: 51 (100%+)
Motolyser for sale if anyone is looking for one.
JustRacin'
"Shut up and Drive!"
Jethroz is offline   Reply With Quote
Old 02-22-2015, 04:18 PM   #94
Cool
Simpler? I strap my GPS to the car and run it down the street. Gives me max mph right on the screen.
Originally Posted by John Wallace2 View Post
Thanks but I have an even simpler way to calculate the speed of my car (without a speed gun) and you don't need all those measurements (e.g., do you know the KV rating of your motor with the amount of timing you are using? - I do but I have a Motorlyser). I run my car flat out in the street in front of my house, download the RPM from the ESC, divide by the FDR and I have the wheel speed in RPM. I can convert that to MPH, KPM, or any other unit of measure I want.
christopher_2 is offline   Reply With Quote
Old 09-18-2015, 07:05 PM   #95
Hi Guys,
I bought my self a Motolyser and I have some questions.
My motolyser shows a 0.15 volt lower supply value. Is there a way to calibrate this?
The Motolyser shows drifting timing values with the same motor and the same settings
1 run 32.5, 36.6, 39.0
2 run 34.5, 35.5, 35.9
and so on.
Have you noticed the same drift or have you stable values?
Thank you
silden is online now   Reply With Quote
Old 09-18-2015, 11:49 PM   #96
Originally Posted by silden View Post
Hi Guys,
and so on.
Thank you
which firmware version?
torg is offline   Reply With Quote
Old 09-18-2015, 11:55 PM   #97
Firmware 142.
The deviation on the tiiming came from the motor. I checked two other and the timimng was consistent. It looks like I grabbed a dull one for the first test.
Old 09-29-2015, 09:39 PM   #98
TORG are you having problems since you upgraded the firmware with the motors shutting down because of too high of current draw? I'm just using 21.5 and 17.5 motors.
Old 09-30-2015, 09:44 AM   #99
Can't say that I have, but then again I haven't re-tested all my motors. Wish they would make a USB readout available as they claimed was possible.
When the high current draw occurs I just turn down the timing on the end bell.
If you don't mind, which motor(s) and at what timing do you see it? If I have the same I can run a test. Otherwise email them, I've found them to be very responsive.
Old 10-01-2015, 11:53 AM   #100
Team Powers 21.5 Timing at 4 (~52 degrees).
Kill Shot Maxilla 17.5 58 degrees on end bell (~45 degrees)
Old 10-01-2015, 12:00 PM   #101
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Have your tried testing with a 1s ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-01-2015, 12:06 PM   #102
Nope! I don't recall having a problem before using my 2S battery.
Old 10-01-2015, 01:52 PM   #103
Neither have I
But, don't have those motors either
Old 10-07-2015, 05:57 AM   #104
I read on here somewhere that the new version had a current cutoff to keep people from burning up the unit.
Old 10-08-2015, 06:01 PM   #105
LOW ET's Avatar
Trader Rating: 95 (100%+)
these checkers seem great for getting motors to the same settings but how do you know what settings are best?
example: i buy a motor, throw it on the checker and sure it gives me info. then what? what am i looking for in the data that tells me to +/- timing or change to a different rotor, etc..? do you first run the motors on track to set them to the best performance, check 'em and then use that as a baseline and just set every other motor up to those settings?
LOW ET is offline   Reply With Quote
