Orion Touch Duo
Orion Touch Duo
Just received this awesome charger! Quick question though, on the menu it has "Charge End Voltage - 4.20V" (default) and "Discharge end voltage - 3.20V" also a default setting. Is this value per cell? Do I need to double this for my 2S 5000mAH Lipo?
Suspended
No that is per cell..you will have to select cell #..2-3-4 so on..
Thanks, yes I've set that up so the max voltage number displayed does change, but not the other minimums. I'm flattered you decided to make your first post in this thread, lol.
Personally I wouldn't discharge them beyond 3.4V as a safety margin, you don't want do damage them.
Given the large number of local shops in Toronto and the GTA with Horizon accounts, I'd advocate buying local. Definitely makes warranty and servicing easy if needed, keeps the local hobby growing as well.
