Savox 1258tg noise (not humming) VIDEO
Savox 1258tg noise VIDEO *** SOLVED ***
so ive got a new savox servo with 1 practice day on it, about 15 2s packs and 3 3s packs. my last run of the day I noticed a really weird chirping/squeak...
at first I thought it was my linkage/servo saver binding but I removed my servo horn and the noise is still there.
sounds to me like a stripped gear but its brand new and intermittent. kinda bummed about it. other than that it works great! take a look
https://www.youtube.com/watch?v=UKxwsp8S3MI
figured out what it was. here ya go..
https://www.youtube.com/watch?v=ZQFPwrwBrl0
what esc are you running? Rx8's, mamba 1/10's and the viper esc among others can glitch the servo, maybe try a bec?
You have a tiny but loud Squirrel stuck in there sir. email them and see what they say, please report back. [email protected]
sounds like the motor takes a quick spin on it's own but that makes no sense because it seems to operate correctly other than the noise... hmmm The gears sound ok, if so maybe the first gear is slipping on the motor shaft ? no... it sounds like it works fine other than that noise. Try holding the wheels and turning... see if there is some slippage inside the swervo. I'd be tempted to take it apart, lube ?
You know if you did it just right by turning left and right quickly you could make it sound like a Club DJ on the turntable....
Here is an update from savox today. I purchased the servo from a user on here but it was sealed new in the package so I guess I'm kinda screwed on this one.
Also I tried holding the wheels to get it to slip and it holds firm no grinding or slipping at all. Kinda stumped. Was waiting to get an answer from them as to what it could be so I could take it apart and fix it myself but this is what they said :
" Hello,
Thank you for the inquiry. That is is an abnormal noise, but I have heard it before.
I would submit this for warranty replacement. There is an RMA procedure described on our site here:
https://www.savoxusa.com/Articles.asp?ID=133
When you are ready to proceed click on 'Submit RMA Request' and fill out the following form. Be sure to attach your receipt at the bottom using the browse button.
Please keep in mind that we are moving our facility this week and approval of the RMA might be toward the end of the week/first of next.
Regards,
Cody C
Savöx USA Support Team "
" Hello,
Regards,
Cody C
