esc shuts off when motor is connected >
Old 07-03-2014, 06:06 PM
Default esc shuts off when motor is connected
I have a 1/16 slash vxl (vxl-3m esc and 380 motor)
With the motor disconnected, the esc turns on and works just fine. it responds to my tx, and everything is good.
but as soon as I connect all 3 wires to the motor, the esc just shuts off.
any idea what the problem could be? do I need to buy a new motor?
Dynikus is offline
Old 07-03-2014, 06:34 PM
Hoese37's Avatar
Your motor is probably shorted out internally.
Hoese37 is offline
Old 07-03-2014, 07:48 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
those traxxas escs are notoriously bad, especially the 1/10 ones that I know of. the motors are typically very good though, so its strange one would go out. it does sound like it is the motor though. if you open it up you should be able to smell a burnt smell or see some burned insulation to check for the motor shorts.
ThePanda is offline
Old 07-03-2014, 08:18 PM
I took it apart and I don't see anything out of the ordinary?
I can't say I've ever taken apart a brushless motor though, so I could be missing something
Dynikus is offline
Old 07-03-2014, 08:27 PM
Hoese37's Avatar
You had something go wrong in there. The wire should be a copper color, not that shiny silver color.
Hoese37 is offline
Old 07-03-2014, 08:36 PM
what do you mean shiny silver color? perhaps it's the lighting, but the wire is all very coppery.
Dynikus is offline
Old 07-04-2014, 05:31 AM
Hoese37's Avatar
I'm referring to the first picture you uploaded. Inside the windings it looks silver. It may be the light.
Hoese37 is offline
Old 07-04-2014, 01:00 PM
it's mostly copper inside, but upon further inspection I think there are a few spots that are silver where I'm guessing the insulation burned and caused a short
Dynikus is offline
Old 07-04-2014, 02:49 PM
TOM MAR's Avatar
Take any ohm meter, check resistance between
blue, yellow
yellow, white
white, blue
They should be very close in resistance. If any reading is 0 ohms or no reading on any of the 2 wires the motor is the problem. The readings should be low, I'm guessing but less than 2 or 3 ohms.
If the motor checks out, you probably have bad esc.
TOM MAR is offline
Old 07-04-2014, 02:54 PM
it reads .8 ohms across all 3
Dynikus is offline
Old 07-04-2014, 03:01 PM
TOM MAR's Avatar
Sounds like the motor is good. Probably something with the esc , setup, or wiring
TOM MAR is offline
Old 07-04-2014, 03:34 PM
how do I test if my esc is bad?
like I said, without the motor, the esc seems to be working fine. it powers on and off, and responds to my transmitter input
Dynikus is offline
Old 07-04-2014, 03:55 PM
R/C Tech Elite Member
EricW's Avatar
You can't really determine if the esc is good or bad based on the lights that come on without a motor connected to it. Do you have another motor you can test with?
EricW is offline
Old 07-04-2014, 03:59 PM
I'm getting a brushless rc18t in the mail soon, hopefully tomorrow or monday. but I don't have any other motors this size
Dynikus is offline
TOM MAR's Avatar
+1
TOM MAR is offline
