Orion R10 Pro issue. HELP,!
I purchased an R10 pro from a guy on this forum a few days ago. I received it today. Upon opening it out of the box it smelt burnt. Quite frustrated. I gave him the benefit of the doubt. We soldered on a new 17.5 T motor and powered it up. It seemed to work. All the LED's lit correctly but no motor function. I was able to calibrate it to my controller. When I plug in the sensor wire nothing happens unless I give the motor a bump. After that as long as I keep power on it works. If it stops then no go until it gets bumped again. If I unplug the sensor wire it seems to function sensor-less. Can not find a setting to say sensored or not. I have another one and it works awesome. I have tried several sensor wires and even tried a different motor. The guy was active and I messages him then all of the sudden he got off line. I emailed him and no return message. Paid with paypal so I hope I am protected.
I will give up the name if he does not make it right.
Yes I have tried both sensor ports. It will run the motor only if I give it a nudge. If it stops it will need another nudge to get going again.
I had an speedpasion do this and it was the capacitor
Thank you all for the info. Regardless if the guy does not get back to me within 24 hrs to make this right it will be turned into paypal. I have already spoke with them. I hope all will work out.
Would love the new one but they are out outrageous to by new. I have never burned anybody and have never been burnt by anybody. I guess there is a first for everything.
Thanks again.
Thanks again.
Oh well.
Sorry to hear about your troubles; hope you get it all worked out.
I if you still have the new one when this gets resolved I will see what I can do.
