Savox 1268-67 swap?
Savox 1268-67 swap?
Can I repair a 1268 servo with a 1267 gearset?
Yes speed/torque would change.
Never tried it but I think it would physically fit. The case is the same I believe between the two servos. Try it and see or do what asc6000 says and contact savox customer service and ask the same question. Please post the answer/results here for all to see!
Nope
According to Savox support, at this time there are no known interchangeable gearsets for their servos.
The motor/PCB component is specific to the servo. This is what I was wondering, because without a positional marking on the final splined shaft, I couldn't see how the servo would know that it was over-rotating if you changed out the gearset. So, this one will stay a 1268 once I get the replacement gearset installed.
Is the case of 1267 n 1268 interchangeable?
