ESC SWITCH
ESC SWITCH
Hello all... The esc on my sidewinder sv2 came off and was wondering if it will work with an accessory esc off/on switch?? Also, I had it plugged into my receiver and I couldn't test it with the battery plugged in.. Any suggestions to see if it still works??? Any help appreciated!!!
You can just twist or solder the two switch wires together. It's a fairly common thing since many external esc switches aren't very reliable. I had to do this on my Mamba Max Pro and a couple LRP esc's that I have. Truck would cut out every once in a while, usually after a hard landing. Eliminated the switch and haven't had any issues since.
