Thunder power 820cd charger issue???
Hey guys, having a slight issue with my charger. While balance charging a 2s pack it will charge my pack to normal voltage of 8.4 volts. But if I don't balance charge them is only charges to 8.1 volts. I'm turning off the balance function on the main screen but that doesnt help. Any help would be appreciated. Not sure if there are any settings in the charger that I need to change.
It might be a factory setting so that if you aren't balance charging you won't accidentally overcharge one of the cells and cause… bad things… to happen
But as a side note, you should always balance charge your batteries anyways to be on the safe side, and your charger is charging just fine while balancing so I would say to stick to that
