New Sanwa MT4S
New Sanwa MT4S
http://sanwa-denshi.co.jp/rc/car/propo/mt-4s.html
No info on release date as far as I can see.
But it does have the backlit screen and M12 response times.
Looks like a decent upgrade for the MT4.
Does anyone have more info about this radio?
I 1st found this link in the m12 thread a few months ago. With what littls I can glean from that page, it appears to be m12 firmware in an mt-4 form factor. My question is why this was never reported on international news sites (redrc, neobuggy, etc). Is this a domestic only product? Is it a future product? Has anyone heard anything else about this radio?
I just translated this via google translator. lol
Sanwa introduces the MT-4S, an updated version of the popular 2.4 GHz remote control MT-4. By the SSL function (Sanwa Synchronized link) of the MT-4S can be read and store the engine speed and the temperature controller, also the display is illuminated. To have the knob transmitter expected from Q1/2014.
features:
Backlit display with adjustable contrast
Transmission speed as M12
Sanwa Synchronized Link for controller programming on the transmitter
Telemetry function (receiver voltage, speed & temperature)
Four channels
18 model memory
features:
Four channels
18 model memory
Hideeho
Assuming this is priced similar to the current mt-4, what is the point of the m12 once this comes out? A drop down? I'll get the grid drop down. Even at $300 I'll get one of these over the m12. $350 puts in a close choice. More than that I'll probably end up with an m12.
regarding the features it will be a steal if the price is similar to the MT4
is it faster than m11x with rx 451R ?
Hideeho
By the translated add, it seems to have the same firmware as the m12. So, yes, it has the zero latency of the m12 so it is quicker than the m11x. Either way, an MT-4 with a 461, 462, 471, or 472 will be faster than an m11x with a 451r. The 451r is an fh3 receiver & is not as fast an fh4 receiver.
Please correct me if I am wrong. To get the actual zero latency you have to use the m12 (or mt-4s) AND a 471 or 472 receiver. The 461 & 462 are fh4 but do not support zero latency.
http://www.rcmart.com/24ghz-rx472-sr...ml?cPath=36_47
Sanwa MT-4S 2.4GHz 4Ch SSL CODE AUX Back Light w/ RX-472 & SRM-102 x 2 #MT-4S
Description:
This is a MT-4s 2.4GHz 4Ch Radio telemetry system that has greatly improved from the MT-4. The response time is claimed to be twice as fast as the MT-4 which mean it comes really close to the M12. LCD display is now equipped with white back light to ensure adjusting parameters at low light environment will not be an issue anymore. The MT-4s also equipped with the latest SSL (Sanwa Synchronized Link) Function to allows adjusting ESC setting on the run (only for ESC support SSL features).
Feature:
Receiver:
Include:
Description:
Feature:
- SSL Supported (Sanwa Synchronized Link)
- Ultra Fast Response Time
- Display Panel with back-light function
- CoDE AUX
- 4 Channels
- 18 Model Memory
- Digital Screen
- Fast Response
- SSR-Compatible
- Telemetry. Receiver Voltage, Multiple Temp Sensors and Engine/Motor RPM
- 1 RPM and 1 Temp Sensor are Included
- Assignable Switches and Functions
- Programmable Mix
- Step Mix
- Point Mix
- 4WS Mix
- MOA Mix (Motor on Axle)
- Multiple Curves and EPA
- Multiple EPA Types
- Adjustable Servo Speed
- Anti-Lock Braking
- Alarms with Audible Tone and Volume Adjust.
- Model Naming
- User Name
- Throttle 50/50 & 70/30
- Includes 2 Grips for Customization
- TX Battery Range, 4 cell dry AA to 2S LiPO
- Compatible with RX-461, 462, 471 and other receivers
- Compatible with almost ALL servos available today.
Receiver:
- Model:RX-472
Include:
- Sanwa MT-4s 2.4GHz Transmitter (1pc)
- RX-472 FHSS-4T Receiver (1pc)
- SRM 102 (2pcs)
- Switch (1pc)
- Battery holder (1pc)
- Extra Handle Grip (1pc)
- Manual
