My laps transponder & spektrum rx help
I am about to purchase a my laps transponder for my buggies, but I am running spectrum SR300 & SR3000 receivers in my buggies. I am running savox SC 0254MG and Savox SC 1258tg servos so I use glitch busters to prevent brown outs. So my question is my rx has 4 inputs throttle, steering, aux, and battery/tel. The only input open is the batt./tel. is this where my transponder plugs into or do I need to remove the glitch buster from the aux input.
Transponder in batt works just fine.
If you are thinking of getting the newest 3 wire RC4, not the hybrid 2 wire, this thread is worth reviewing:
http://www.rctech.net/forum/radio-el...ansponder.html
Also perhaps try the glitch buster in the bind port if the transponder causes a bind issue, maybe that will work? If all else fails a Y servo harness in the aux port should work.
If I remember correctly the 3 wire has an extra digit so you can have multiple transponders with the same base number and just the extra digit different. And is capable of measuring temperature I think. But only works with the new RC4 decoder, which all tracks may not have. There is a sticky at the top of this section that explains most of it correctly I believe.
The hybrid is probably the better one to have, as it works with both the old and new track decoder. Should work fine in the bind port.
