hobbywing xerun 120a and speed passion 13.5r
#19
so I entered the values into the Novak starting sheet...
11 FDR / 2.6 tranny = 4.23 (spur/pinion ratio)
and I get
FDR = 11
Trans ratio = 2.6 (from manual)
Spur/Pinion Ratio = 4.23
Existing Spur = 96 (Stock)
96 spur / 4.23 = 22.69 pinion
Please double check as this doesnt jive with what people are suggesting...
Sorry to be a pain, but I am trying to do my homework.
Thank you for reading
Fritz
#20
Calculation for 5.5t motor
and I get
FDR = 11
Fritz
and I get
FDR = 11
Fritz
#22
Thanks Guys
I will get an 18...
I am just curious.
and my math OCD kicking in...
does the math not work for belt driven 4wd trucks?
And does anyone have a source for pinion collections?
i see them available individually at 5-6 bucks per...
would cost much to get the range...
thanks again
Fritz
I will get an 18...
I am just curious.
thanks again
Fritz
#23
the math is only part of it. What your doing with it matters also. Like bashing and running it for 30 minutes. Start conservative and work your way up in gearing. And check temps often. 4x4 temps need to be monitored more so than 2wd because of the strain on the motor and packs.
#24
Thanks Guys
I will get an 18...
I am just curious.
thanks again
Fritz
I will get an 18...
I am just curious.
thanks again
Fritz
So anyway the issue with 4wd (belt driven doesn't really matter) and MT is that 4wd and the larger heavier wheel/tire combo will result in more power needed by the motor. Going to lower and lower turns will give more speed but not the power that's why several have suggested 4 pole motors...for the power.
Is this the motor you're talking about now? http://www.speedpassion.net/us/produ...138803V2&c=MTR
#26
Well right that's why I'm questioning it. I went to the Speed Passion site and that's the only 5.5R series 2 motor listed...and it's a 1/8 motor. They sure don't give a ton of detail on their site but I'd assume that's a 4 pole motor and if it is the one he's looking at I'm not so sure it would work with the ESC he has...or not for long anyway.
#29
The motor which I smoked is the 13.5t
Ill post a picture of it..
I have a 5.5 that is being saved until I feel more confident that I wont smoke it as well
Still trying to figure out how/what difference is of four pole motor.
So far I think I know this much
lower turns more speed less power
higher turns more power less speed
Not sure how poles figure into this.
Learning about gearing from the other post I made about my sons' XX and XXX-ts
Thanks for educating this newb
#30
Hey all and happy new year
Sorry for the delay but life happened
Here is the picture of the motor i smoked
It oscillates when i pull trigger. And leads get exceedingly hot after a few seconds
I have bought a four pole 4000kv motor from hobbywing and installed that. Is it a characteristic of four pole motors to not "coast" when trigger is in neutral?
If not then i may need to reset the esc.
Please let me know about the coasting in neutral
Fritz
Fritz
