ICHARGER 308 Duo
#421
Thermostat:KSD9700 40ºC : 104ºF : N.O. NO:Temperature:BiMetal Switch
Make sure you get a N.O. switch, normally open. They sent me the wrong switch at 1st ( N.C. ) and had to resend the correct switch. Seller was great though and fixed their mistake very quick.
My fan was 6V and wired up through a volatage regulator, so I wired the switch into the negative lead of the fan. The switch is slightly wider than the space between the resistors, but since I was replacing the resistors I opened up the spacing a bit to fit the switch in. Switch is attached with thermal tape, which I also used to mount the resistors.
Pictures show the hook up and the spacing where the switch is mounted.
Bruce
#423
Then plugged in a cable, and left for about 30 minutes. Temp rose to 103.6f
It was interesting.. as soon as I disconnected the balance plug temperature dropped immediately. I then plugged in again and left-in.. got distracted. Came back a while later an the temp was at 107.4f with the fans running. Again, pulled the cable out and temp dropped.
#426
TQ Wire does offer a nice cable set with a built-in switch that goes back and forth between 1 and 2 cell packs.
Otherwise, they also have cables configured for either 1 or 2 cell.
FYI...I have no experience beyond 2 cell packs...LOL
Bill
#427
You can get charge leads here www.rlpower.net along with other charger accessories at good prices.
#428
Do any of you change the storage default? The default discharge is 2A and cutoff is 3.5v.
#430
What number of cells are your packs?
Bill
Bill
#431
Would love to... along with power supply+discharger+cables! But no shipping to Canada
#432
Having an issue hoping someone can help. Have a 308 and the right side at times doesn't want to turn on. When it is on and charging my charging plugs are hot. This only happens on the right side. It's not the leads as there is no heat issue to the left side using the same lead.
