Stutters under initial soft throttle????? Help!!!!!
I have a tekin rs gen 2, with a reedy Mach 2 17.5 in my offload buggy. I am having trouble with it wanting to stutter when I barely give it throttle? If I punch it no problem. If I take the weight of the wheels an hold the buggy in the air, no issues, smooth as glass. I have replaced the sensor wire with 5 news ones, I have just replaced my motor with another one, (same brand and type) and it still does it. I first thought it was sensor wire, then sensor board in motor, now I'm thinking maybe something isn't set right in my tekin, settings/sensor board. I have 20 neutral width, throttle min is 10, current limit is 50. Could it be one of these settings. Also I have calibrated my remote to esc, neutral, throttle, brake, multiple times. If you have any insight please post. Thanks for you time.
How little throttle is being applied? If you're talking about super minimal amounts of throttle, then that's pretty normal.
You could try lowering your neutral width in order to activate more throttle sooner which would help a bit. For example, on my HW v3.1, I run the lowest amount of dead band width (called neutral width on the HW).
Thanks for the reply. I am talking the smallest amount possible. I will try lowering my neutral width. Thank you!
Why would u wanna use 2-3 % throttle
the point im trying to get across through a computer is, when i first give the buggy throttle, under load (tires on ground) it wants to chatter the spur/pinion tog and not move. I can punch the throttle like I will be doing most of the time when racing and its fine, but i dont want to be on the starting grid for the main and get run over because of a problem from a stand still. when I barely give it throttle, 2-3% holding the buggy in the air, it has no problems and sounds like it should. Maybe im used to a touring car and 64 pitch gears and super smooth 4wd excelleration, but this just seems like I have something in the speedo wrong. Maybe having my current limiter at 50 and not off? maybe I should increase or decrease my initial throttle minimum??? thanks
