balance board help
Doesn't matter, they are all in parallel with each other.
The Paraboard has plugs for both Deans and balance taps. The Deans are in the middle. They are available with other main plug and balance connector types. It is for parallel charging multiple packs of equal cell count at the same time. I can post pictures with everything hooked up to make it clearer, later when I get to a real computer.
Here is a typical parallel board hookup. Both main wires and balance wires are connected both from packs and to the charger.
- Packs must be the same series cell count.
- Ideally packs should be reasonably close in voltage, perhaps within a couple tenths.
- Packs should be in reasonably good balance and condition.
- Capacity of packs can be different. Yes, they really can, even by a lot.
